[ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
    Originally posted by danielelek90 View Post
    superceleron I am unable to get into recovery using the reset button method, do you know why?
    dunno... i think is time for me to make a A7 ATV build for this box... in the next few days...
      superceleron and an update for the SCV1 Normal Android!
        yes i will be making both!
          Awesome! Can't wait to test! Will you be able to fix the recovery by reset button, that would be a gem!
            hu?? i have no problems here! but dont matter..
              Yeah, the reset button to recovery doesn't work for me. No idea why! Even tried the SD recovery method, still won't work.
                well you m8 have broken it, the buttons on this GT1 boxes are very fragile, i broke mine on my old GT1 one so needed to soldered another.
                But if you get to bootloader mode the button should be fine.
                Leave it pressed for a longer period.
                  I don't have a GT1 it's a R-TV S10 probably why recovery by reset button doesn't work?
                  • trebor
                    trebor commented
                    Editing a comment
                    Yer my S10 2/16 won't go to recovery...
                  Ho... that is different, yes the hw pins m8 be different!
                    Would it help if I used stock boot loader with your ROM? or would that not work?
                      yes it should!
                        yes it should!
                        Nah! Didn't work unfortunately, didn't go past first boot screen. Never mind!
                          well move on
                          I really need to start in this ones...
                            Looking forward to the A7 update SC but with me not having a pc I'm afraid I'll be stuck on the first version of this rom unless I can find an alternate method to upgrade, thanks anyway, the atv rom you have provided so far is superior to the beelink rom in so many ways
                            Sent from my D6603 using Tapatalk
                              I installed SCV1-ATV for AP6255 by sdcard, now I want to update to SVC2 but there is no IMG file.
                              Is there any way to update with SVC2 OTA without usb cable?
