[ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
Not necessary to go on in French
I thought your question was refering to remote applet from IPhone. (that does not work)
On my side, I did not need to make such factory resets when I upgraded to SVC1 and then SVC2
But perhaps I miss a lot !
I will as soon as Superceleron will release its brand new ROM
Phil
Originally posted by momocampo View PostMerci beaucoup Philippe
Ok so I think I'm gonna try
What scv2 are you used? 6255 or 9377?
Thanks.
I got a G1 Ultimate with AX12 serial number and I used SCV1 and 6255. This is the only firmware I was able to get kodi running okay without stuttering. You can also use the Android TV version.
just flash SCV1 first with usb burner tool and then put SVC2 zip file on a sdmicro card and then run this zip file from twrp.
Just new on this Forum, my name is Fred from France
I get a GT1 Ultimate 3GB DDR4 AX12xxxx under Android 7.1.2 Build 703NO
I have discover this forum and this topic about SVC1 Flash ... but fall in error (early because each time I restart the box as usual ... I will be back on working 7.1.2 ??? )
With Amalogic USB Burning 2.0.9 even about said 2.0.7.2 ?
... device is correctly recognize when connect using USB (male Male link ... and without any other things connected to GT1 )
... image check OK, unchecked the "erase bootlaoder", check others
... Start and early error : [0x10101002RomCode/Initialze DDR/Identify/USB Control Setup then nothing more (Box restart as usual after (replug power cord)
Using the Burn Card Maker
... Update start, Update logo, clear another Update logo and it's alll
The GT1 is not bricked ... restart each time with stock 7.1.2
Any advice ?
Thanks.
Fred.Last edited by fred.lacrima; 22 October 2017, 16:39.
Originally posted by momocampo View PostHello,
Ok, big thanks !!!
I already flash with scv1 with success
Let's do it with the scv2 by sd card.
Cheers
I think I have maybe find the problem : I flashed with SCV1 NORMAL ANDROID and maybe I must flash with SCV1 TV ANDROID first then flash with SCV2 ATV. What do you think?
If I'm right, do I flash the SVC1 atv with burning tool or I can do it with recovery?
Thanks.
Any advice ?
Thanks.
Fred.
Any advice ?
Thanks.
Fred.
Good luck.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 3131 users online. 1 members and 3130 guests.
