thx
[ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
This is my problem if im watching a movie from my sd card. https://www.youtube.com/watch?v=PnX-ANQgW5E
Not issue of sd card or hdmi cable..
Im running currently 708N0 on AX12...
Is there any fix or probably it could run eather on your rom ?
hello, superceleron
Can you please show me how to use the Samba Server.
Do you know an ATV compatible application? I found several but not compatible ATV. Thank you.
Hello
I've tried to flash V1 IMG without sucess.
I managed to USB burning tool detect my box (SN A706D) with usb cable and i unticked erase bootloader.
The process finished with green 100% sucess! but when i connect to my tv i've no signal.
Next i flashed the original firmware again with sucess and now i got signal a the box worked properly.
I tried again to flash this V1 IMG and iv got the same problem: the process finished without any error but no signal on tv.
Pissed of with this situation i tried again to flash the original firmware but now i can't anymore the get the USB burning toot to detect my box,
Ive tried everthing: other USB cable, the short circuit, etc, etc.
Can you help with this? or are there one paper weight around?
Originally posted by verseau71 View PostHello, I had exactly the same problem that I was able to solve after several attempts with the method of short pins. Good luck
philippe
Hello
Here same with me, I want desperate to try this rom but I am sad,
when flashing SCV1-ATV-GT1_Ultimate.img with"Erase Bootloader" disabled rich out with all good up 100% without error but no signal from box.
When try to flash with "Erase Bootloader" enabled rich until 3% with error.
Any idea acceptable, please.
I would suggest that you use another ROM ( from Magendansk or Tillaz) as this Superceleron ones are old and obsolete. So surely not good for any recent Box.
regards
philippe
Originally posted by Gus View PostThose two you refer are Android Tv?
Currently I'm on Alvatech's rom.
Στάλθηκε από το Redmi Pro μου χρησιμοποιώντας Tapatalk
Tillaz provides the ATV ROM (with a way to patch toward non ATV but I am not sure it is still valid)
currently I use the last Tillaz ATV version on an AX25 version and on an D706 version without any issue
Regards
Philippe
There are currently 2279 users online. 2 members and 2277 guests.
