[ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
Hello,
I received my gt1 ultimate
Serial number start with A706DSB...
My wifi chip is AP6255
When I try to flash the GT1 with SCV1-ATV firmware with USB or SD, the flashing process is ok but no hdmi and if I connect on my computer, usb burning tool don't detect the box.
The box "erase bootloader" is correctly unchecked
I need to short 2 pins to unbrick the gt1. If I flash with the original firmware, the box booting and I have image on screen.
I tried with scv1 and scv1-atv but same result.
Any clue ?
Hi guys,
I bought two Beelink GT1 Ultimate boxes, for me and my brother. I configured mine first, installed Kodi with addons and Youtube,had no problems whatsoever and everything works fine. Today I installed Kodi on the second box but when I try to install addons it always freezes at some point and a popup appears saying it´s not responding and I have to close it. I dont understand why this happens with only one box. Both have stock rom with the latest update availble OTA. Can someone help me?
I also would like to install superceleron´s rom on both boxes but I dont know how to do it properly and I´m afraid of ruining the boxes. I have some urgency in solving this because my brother is leaving Portugal in the 31st.
superceleron is there a tutorial for newbies to install your rom ?
superceleron is there a way to make Netflix app work on his firmware?
Neither android tv or regular works fine.
But the rest, works like a charm
congrats and thank you
Hi I just update my gt1 ultimate for the second time ,first time was few months ago and every thing went well with the SCV1-TV,SCV2-TV and theSCV1ATV 9377 WIFI/BT SUPPORTBut now I have some problems to use theSCV2-TV and theSCV1ATV 9377 WIFI/BT SUPPORT. After Flashing the SCV1-TV I tried to use the SCV2-TV and theSCV1ATV 9377 WIFI/BT SUPPORTtrue system update and the system turned on to TWRP mode. I tried to install the zip file but cant find it, when try to chose drive only internal storage was recognized at the TWRP mode. when I looked at the prompt window there was a message the it cant find the zip file. I need help my gt1 is now stuck with SCV1-TV with no wifi connection, only the wired on is working.
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Originally posted by ohadmiz View PostHi I just update my gt1 ultimate for the second time ,first time was few months ago and every thing went well with the SCV1-TV,SCV2-TV and theSCV1ATV 9377 WIFI/BT SUPPORTBut now I have some problems to use theSCV2-TV and theSCV1ATV 9377 WIFI/BT SUPPORT. After Flashing the SCV1-TV I tried to use the SCV2-TV and theSCV1ATV 9377 WIFI/BT SUPPORTtrue system update and the system turned on to TWRP mode. I tried to install the zip file but cant find it, when try to chose drive only internal storage was recognized at the TWRP mode. when I looked at the prompt window there was a message the it cant find the zip file. I need help my gt1 is now stuck with SCV1-TV with no wifi connection, only the wired on is working.
I did the same few months ago ( same files, same gt1 unit) and every thing went well. I tried this time to move to SCV1 regular android ver and have the problems described above, so I tried to move back to the android TV ver that was installed by me on the device few months ago and no success, I have the same problem describe above. I may do something wrong, probably something wrong in the process, it worked on this unit' but no more now. Pleas help!
Pleas if some one can explain how to use the SCV2-TV and the SCV1ATV 9377 WIFI/BT SUPPORT once again, and how to pass the TWRP process.
Thanks in a head.
There are currently 2181 users online. 0 members and 2181 guests.
