[ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
Guest
Greetings,
First of all, I want to thank superceleron for his work on this rom, it is really nice and nearly perfect for me... But sadly I have a weird issues with BT
I was able to pair my "August EP650" headphones, I can hear the system sounds of the Android TV menu and I was able to check a video on FTMC once, then afterwards there was no more sound on any videos (BT still paired), then I tried using Youtube app, all video were either freezing or lagging (my first though was CPU usage or something similar, I was wrong...) when I turn off the bluetooth all videos and audio runs perfectly.... then when I turn it back on, all videos freezes...
does anyone have a fix for this bluetooth issue? (I tried to pair another heatphone but It doesnt sync with it).. I will try with a BT USB dongle I have layin around..
(FYI : I have the model G912 (QCA9377), I flashed V1 then 9377 V2)
Guest
Well this rom is to old now, i really need to update it... but this lack of time is killing me!I decided to fix my issue by ordering a Bluetooth Transmitter plugged directly into my tv so it will work with all my devices, thanks for this great rom anyway
I will buy the beelink gt1 ultimate at the end of this week .
What is the most up-to-date rom you can get?
I would be very grateful .
Thank you
Hello All,
I am running the SCV1-ATV-GT1_Ultimate.img on my H96 Pro Plus and so far it is working fine. Android version 6.
I am wondering if anyone tried to use the VPN option on this.
I know it gives me the option to go into VPN but when I select it it never comes up.
Was thinking of either updating to Version 2 of the firmware or maybe one of the Alfawise H96 Firmwares.
Any help would be appreciated.
Guest
Hello,
My device :
GT1 Ultimate 3Go RAM DDR4 - 32 Go
S/N : LPN1..xxxx
firmware : GT1_710N1 xxxxx
Is this rom compatible ???
So, i can't Using Amlogic's USB Burning Tool... If this rom is compatible, Burn card maker can be used for flashy my device ?
thanking you in advance for your reply,
Best regards
There are currently 3960 users online. 0 members and 3960 guests.
