Another thing, can anyone guide me on how to on how to update to SCV2 since I'm on SCV1. Just flash the way I did for the SCV1 will do the trick?
[ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
Originally posted by wojciech679 View Post
Another thing, can anyone guide me on how to on how to update to SCV2 since I'm on SCV1. Just flash the way I did for the SCV1 will do the trick?Last edited by louvadeus; 22 June 2017, 22:50. Reason: Forgot to ask something, and didn't want to submit many posts
Originally posted by louvadeus View Post
Hi, I use a air mouse with keyboard... I don't know what am I missing.
If you flash SCV2-ATV you can use OTA update or TWRP. I used TWRP (you must copy SCV2-ATV on microsd card, FAT 32 formatted) and flash via TWRP. For me works great!
By the way, thank you superceleron for your work!
I'm currently using the latest ATV version but does anyone have screenshots of the normal one (non TV one)? I love the way this works but can't get used to the way it looks. Does the normal one look like the Beelink firmware?
TIA - amazing firmware with how it works!
Also, could I upgrade to normal from ATV?
Ok i done it!!!
My box is Alfawise H96 pro+ with chipset pp026-093e dg q9377
The method was with sd installation and the burncardmaker
(x) To Partition and Format
(x) erase bootloader
(x) erase flash "force full erase all"
(x) reboot
After the installation i installed the ota update over the twrp .
Everything works like charm except the ir remote and the fireasy any solution for that?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
(x) reboot
ok and how can i fix the remote? i choose the both versions in settings but without luck
I'm using the one from this post: http://freaktab.com/forum/tv-player-...547#post640547
Originally posted by veey View Post
You need to edit the remote.conf file in /system/etc/
Ok i edit the conf but i have issues with the root . i have enable root i have su but getting su binary occupied and i cant get root acces to explores
Root is fine here, only had problem when I tried to replace the original remote.conf with the edited one, so I've copied the content of the file and pasted into the original with file commander, instead of replacing the file. Worked for me
(x) reboot
I have the same problem, my remote control doesn't work with SCV2
You have the solution
My box is Alfawise H96 Pro+ 3go DDR4 32goLast edited by twedie; 27 June 2017, 10:11.Beelink GT1 Ultimate DDR4 / 32go
AlfaWise H96 PRO+ DDR4 / 32go
There are currently 2143 users online. 2 members and 2141 guests.
