[ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
Originally posted by jhonb View PostHello to everyone and big thans to superceleron for this rom.
I haven't the needed usb cable so i need to flash the rom whitout pc. Is it possible to flash with flashfy or something else?
Originally posted by elio7 View PostHave you already connected bluetooth earpods to this box?
I connect my BT phones to smartphone and my TV, but I can't find them on the Beelink GT1 ultimate...
But I can find a gamepad, a smartphone, and a smartwatch xiaomi on this Beelink.
Very weird...
@superceleron or someone else, can you help me here?
Originally posted by marko33 View Post
you can use usb burn tool to make an sd card updater. make sure erase bootloader is UNTICKED and the other 3 options ticked. remove power, insert sd, hold reset and reinsert power. if it hangs dont worry, just remove power cable and re insert with reset button pressed, install will finish. i have used this method on my gt1 ultimate sn a912 without issue, as always use these instructions at your own risk.
More thanks for Mr Celeron, excellent work.
Installed on my Ultimate using burncardmaker with no problems.
I bought the Ultimate only because i knew Superceleron had a f/w for it, having used it on my Qbox for months, and i'm glad he has because the stock f/w was awful, anyone buying the Ultimate and had never heard of boot card maker or usb burning tool would i'm sure have been returning the box.
First impressions - i'm not sure if i like the atv home screen and there doesn't seem to be many options to change it, maybe it will grow on me.
Thanks again Superceleron.
Originally posted by pyc View PostI'm completely new in Android TV boxes field. I have Beelink GT1 Ultimate DDR4 32GB 3GB. Are there any tutorial around for flashing this ROM? Seems like I need some USB OTG cable and Windows?
I flashed SC's ATV version with the sd card a few days ago, moving from the latest stock f/w but I did not like the ATV layout so flashed to SC's 'normal android' version again using the sd card, all with no problems.
By the way the Wetek laucher in the normal version is one of the best I have seen.
All done at your own riskgood luck.
I don't see that info in last few posts.... I only found this: http://freaktab.com/forum/tv-player-...509#post640509 Is that the manual you're taking about?
What is the difference actually between Android TV and Normal version?
There are currently 2264 users online. 2 members and 2262 guests.
