I'm going to keep my hopes up though and if we get root I will play with the build.prop and see if I can get it a bit more Google friendly...lol...
R-TV BOX K99 RK3399 Firmware 20170322
CSA96 TV Box RK3399 R-TV BOX K99 RK3399 new firmware uppdate rooted i have tested all ok ok
link:
this firmware is rooted it seems that CSA96 TV Box RK3399 real name HTC t077 RK3399 wifi6255_6.0 has better support
http://www.mediafire.com/file/faigr6...a_20170420.rarLast edited by wahran; 29 April 2017, 07:27.
Originally posted by wahran View PostCSA96 TV Box RK3399 R-TV BOX K99 RK3399 new firmware uppdate rooted i have tested all ok ok
link:
http://www.mediafire.com/file/noftab...0_20170418.img
Originally posted by glockman4519 View Post
This is good news. I just got my Nvidia Shield Pro 2017 hooked up and running so I will have this to just play around with. Thank for the rooted firmware and the heads up.
Originally posted by wahran View Postthis firmware is for rockchip RK3399 with wireless AP6225 not for Nvidia Shield Pro 2017
Updating Firmware to Rooted Version ...
Can Anyone answer this ?
So, To use this updated firmware do I just put it in the root of a properly formatted SD card and let the built in updater find and install it?
Please help
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Please help
Michael T.
use
SD Firmware Tool. v1.45 choose uppgrade firmware uugrade and then create after put it in the box power on it will start uppdating dont forget to take the sd card out before booting the box when the uppdate is finsh
or use
AndroidTool v2.38
or
RKBatchTool-v1.8
hold reset button without power in and connect usb cable
Hello All,
Which image is rooted ???
I tried this img 20170418.img but it is not rooted ...
Please post a link ...
Or A Link to A Root Program that works .... I have tried 4 different Root Programs and NONE of them Work ...
thanks in advance
Michael T.Last edited by michael2t; 15 May 2017, 17:03.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
HTC_t077_RK3399_wifi6255_6.0_chuangsiqi_ota_201704 20
then you can uppgrade to supersu_v2.79-279.apk
(And is is similar, only exchanging a reset button at the back for a power button at the front)
After updating Super SU application through the play store, the su binary update also was a success.
There are currently 3969 users online. 0 members and 3969 guests.
