MK802IV New Wifi Chip AP6210 - Neomode Custom Rom Version 1.0
    well it worked, damn netflix still not hd somtimes good then back to bad quality
      This can also be a Wifi Problem. Check your Wifi with Wifi-Analyzer from Playstore and look how many StationĀ“s are on the same Channel as you. Then change your Channel.
      Neomode
        ok, there is 2 or 3 versions of Rom, which one is the best and recomended?
        please i just opened the mini pc maybe to have a better siginal on wifi...
          It is only 1 Rom, it is a Hybrid Rom. If you have a MK802IV with new Wifi Chip Flash it with the Option kernel1.img.
          Neomode
            There will be any new release soon?
            and thanks so much for support!
              Yes i think so. Need some Time to do it.
              Neomode
                just some info...cozyswan s400
                Hello
                I have tried different combination of ROMs and kernals, and have had the same issues e.g. Screen issues, wifi .
                One combination did work very nicely for me:
                kernal1 (only kernal where Wifi Works) from this thread combined with neotvcr_mk809_3_ug007b_20130615 ROM
                Wifi: aournd 20 Mbit up and down
                Antutu around 15200
                Citadel : 44,7 FPS (lower then stock)
                Hope this combination would work for you..
                Thanks to neomode...Gutte arbeit
                  Originally posted by Knowit999 View Post
                  Hello
                  Antutu around 15200
                  Does your Bluetooth work? I have tried the kernel with a lot of other roms and everything works fine except for Bluetooth.
                    where to download the last original update of MK802IV?
                    every custum ROM got issues and problems, some with wifi some with screenand anothers not playing videos from usb or bad quality please a link to the original software to back up... Please!
                      AW: MK802IV New Wifi Chip AP6210 - Neomode Custom Rom Version 1.0
                      Which stick you have a old or new mk802iV ?
                      We have also have kernels that have frame skipping fixed. May you wasn't try it. The original ROMs are not better.
                        Neomode 1.1 1080p and frame skipping fix
                        Hey Neomode
                        what are the chances that you will make a "stock" custom neomode rom with build in 1080p support, frame skipping fix and unlockd so we can OC?
                        BaDTaG
                          Originally posted by BaDTaG View Post
                          Hey Neomode
                          BaDTaG
                          Also with the scaling issue fixed. That would be my ideal rom as well.
                            No BT sorry... And now I am using 720p new Wifi Kernal ...Video is smooth...But the stick gets a little warmer then usual, but Antutu scores now are 154XX
                              Hey Neomode,
                              Great work. I have a couple questions.
                              Did you include the xpad.ko module in your kernel. I flashed with the other frame skip kernel and it isn't there. Wasn't sure if it was worth trying your or not. USB xbox controller works in OS, but doesn't work in supported games such as shadowgun and dead trigger. xpad.xo module is missing in my rom which is probably why.
                              Also, the directv app won't connect with my USB ethernet adapter, but works fine over wifi. I notice that when I am using LAN the Wifi turns off and the "no internet connection" notification is present. Anyway to make it so shows connection. Not sure if directv app is specifically looking for wifi or absence of the notification.
                              Thanks,
                                HI, Neomode
                                thank you for your work first.
                                But your rom do not work very well on my tv because of
                                scaling and some other self problem,And I want to overclock my MK809III(AP6210 WIFI inside).
                                ps: If I flash your rom combine the 1080Pb
                                overclock kernel of Sam's , It is displayed very small like a window in my 40' SONY TV screen.
                                Can you modify the factory ROM just let it compatible for the overclock kernel of Sam321‘s?
                                Here is the download URL for the newest factory ROM,I tested it works well on my MK809III.
                                http://pan.baidu.com/share/link?shareid=3168373304&uk=1795611152
