MK802IV New Wifi Chip AP6210 - Neomode Custom Rom Version 1.0
    Originally posted by BaDTaG View Post
    Yes i have tryd it myself :-)
    I tested it. WIFI working ,BUT bluetooth not working!(use sam'kernel)
    video play is not perfect but can play now,No scaling problem.
    So maybe is it suitable for me at this moment.
    I am aslo waiting for NEOMODE 's ROM!!!
      okay it is good that it is working... i dit not kow that bt was not working i dont use it so that is way i dit not know :-/
      regarding video play i can do nothing. i dont understand way it is not working with you.
      mine runs perfectly fine. a small amount of microstutter but that is it. (i am on neomode rom + 1080p 1.7 ghz 1000 kernel.)
      i am just waiting for the new kernel with GPU OC then i will be happy for now.
        ,If you only want to try it ,maybe GPU OC kernel can work on your divce but WIFI not work.
        By the way ,you can test bluetooth, if it can be turn on,it is ok. I can not turn on it.
          yes but i neeed my wifi all my stuf is on my Synology NAS. )
          ill just wait til sam321 has time to make a new updated kernel for the AP6210
          EDIT:
          i could not wait so i tested the 1.8 1080p one and i got about 16000 in antutu. it seams to work great but the stick gets a bit hot so i think for daily use a 1.7 would be better.
          or i just need to get the time to fit a better fan on my custom case insted of the 40mm i haw on there now.
            mk809iii
            Hello neo,
            few questions
            do your Roms support touchscreen drivers? i have the same mk809iii as howard want a custom rom for it with oc touchscreen ect... i am willing to donate if you could make all the above working let me know if interested
            Cruz.
              Hello,
              I have uploaded some Touch Screen Modules. Try it with this Modules.
              To use it Install "Terminal Emulator" from Playstore.
              Then copy the Modules to your Internal Memory and make the follow:
              su
              insmod name of the module
              Than Test it.
              Neomode
              Download:
                Originally posted by neomode View Post
                Hello,
                su
                Than Test it.
                Neomode
                Download:
                http://www.freak-tab.de/neomode/ko%20modules.zip
                just donated i hopefully these touchscreen modules will work thanks again neo for your hardwork will confirm when i arrive home if they work or not, any idea how long it will take you to come up with a rom?
                cruz.
                  cruz.
                  All but usbtouchscreen.ko failed still can't use sixaxis ps3 controller though......
                  Cruz
                    Cruz
                    Got sixaxis working so usbmodule may have worked not sure though just need a good rom now
                      AW: MK802IV New Wifi Chip AP6210 - Neomode Custom Rom Version 1.0
                      Working on a update my custom Rom. Will come the next days.
                      Neomode
                        Neomode
                        Will this work with my mk809 iii? If yes will donate more when finished and working
                        Cruz.
                          Yes it should work because MK802IV and
                          your device are the same. I can test the kernel if it boot but not the Wi-Fi because I have a older one.
                          Neomode
                            Neomode
                            look forward to testing it out!
                            cruz
                              it have Gameloft fix + Droidmote fix + 1080p xbmc? thanks
                                Is this suppose to work with the Cozyswan s400 with WIFI AP6210? I tried it with both kernel.img, and kernel1.img and wifi didn't work with either.
