ALF912PRO+ DDR4 DEBLOATED FIRMWARE
    I took the released rom and debloated it no malware or add ins. Let me know what else is missing.
    Flash Instructions
    Use Burning tool https://www.dropbox.com/sh/9y3e0xge4tpcjh2/AADQ93wDcgeRct2dX2AjjwrBa/setup_v2.0.8.exe?dl=0
    how to use flash tool http://androidpcreview.com/how-to-use-the-amlogic-usb-burning-tool-to-manually-update-firmware/3749/
    Download and install this file into your burning tool Licence directory before starting the burning tool. (If you load without doing this you will get failed to get key error on flash. its normally in this directory
    c:/programfiles/amilogic/burning tool/licence
    https://www.dropbox.com/s/8gwrcd6d43t6pqj/mac_ether.ini?dl=0
    Change log.
    Added FTMC- Super Celeron
    Added Wallpaper
    Added - Tv Launcher
    Added - Root explorer
    Added- Vevo (Everyone loves music
    Added- Root Flashfire- You will have to install super su and long press on permission to get working maybe another video?
    Debloated took everything out that was suspect. left with one launcher and ill post some screen of it shortly...
    This ONLY WORKS ON ALF PRO + DDR4 DEVICES. NOTHING ELSE TESTED USE WITH WARNING ANYTHING HAPPENS TO YOUR DEVICE WASNT ME
    https://www.dropbox.com/s/8ezickq4gqotjt3/ALFDDR4RBETA.img?dl=0
    Your expertise is greatly appreciated. Many Thanks!
      More like lack of lol.... without the best Devs around freaktab none of this would be possible.
Name:
ID:	637659Click image for larger version
Name:
ID:	637668Click image for larger version
Name:
ID:	637667Click image for larger version
Name:
ID:	637666Click image for larger version
Name:
ID:	637665Click image for larger version
Name:
ID:	637660Click image for larger version
Name:
ID:	637663Click image for larger version
Name:
ID:	637662Click image for larger version
Name:
        You may only view thumbnails in this gallery. This gallery has 11 photos.
          Could run on the H96 pro+ with DDR4?
            Not know... It should if same wifi ect... Unless you have stock firmware back for back up wouldnt try.
              Going to try and see if i can get wifi better with a few tweeks its not the worst ive seen but not that great.... Its bullet type so should be better then it is???? Maybe spot they pick interfer or bad soder I check tonight.
                Moved the WiFi carefully to new spot so away from WiFi chip better results
                  hi! what do you mean when you said moved wifi?
                    Opened the box and removed tape on the bullet type wifi and relocated it so it was positioned away from the wifi chip.
                    Two clips on hdmi side push in and pry slowly in center till clip pops off then slowly pull it up. Screws on main board and wifi (bullet type under board) taped in place.... Not a novice fix but can be done carefully.
                      ok thanks man! if you can provide pictures to help guide the rest of us, that will be great too!
                        Ok i post tonight unless Bluesmark posts it before i do.
                          https://youtu.be/M-JA3g_DbXQ.
                          I put life and limbs in huge perial to bring this to you. Done quickly on someones countertop.... She sees this i am a very dead man. Shows how to open my wifi poped off during but i once tape set it will stay in place just more it so it doesnt sit over wifi chip.
                            How can you tell if you have ddr3 or ddr4 RAM?
                            I figured it out , It's on the motherboard . You have to open the case and it's printed on the board ..
                              SyberMile So, what did you get? It should be possible to do that in software, though. Any Android memory benchmarks you could run?
