ALF912PRO+ DDR4 DEBLOATED FIRMWARE
You have a ddr4 just post a photo of the wifi chip then youll know what firmware you can flash.
Best firmware is SuperCelerons so if you have wifi chip his use it possible to have better software.
http://freaktab.com/forum/tv-player-...ndroid-tv-ddr4. Don't forget flash WiFi fix.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
scooter2014, Thanks for the firmware.
Finally I have flashed my H96pro+ (DDR4) with your ROM here.
Was trying to backup my rom with TWRP from Abdul_Pt that make for Beelink GT1.
Successful backup but error on restoring system partition, thus coz my original rom stuck with boot logo.
Tried you firmware here and flashed using Burning Tool 2.08, and without erase bootloader.
So far everything is working and speedy.
Just one minor question here, if I want to have original launcher, could you direct me on how to getting it back?
Once again thanks.
Originally posted by scooter2014 View PostOpened the box and removed tape on the bullet type wifi and relocated it so it was positioned away from the wifi chip.
Two clips on hdmi side push in and pry slowly in center till clip pops off then slowly pull it up. Screws on main board and wifi (bullet type under board) taped in place.... Not a novice fix but can be done carefully.
Originally posted by scooter2014 View PostTry Ftmc not kodi 17
I am starting to this it is the H96pro+ (DDR4)
The firestick just works perfect for those hi bitrate 1080p files, about 8GB per episode
Once again thanks.
There are currently 2286 users online. 0 members and 2286 guests.
