ALF912PRO+ DDR4 DEBLOATED FIRMWARE
    Ive got a new firmware that has some new things added. If someone wants to beta it let me know some of art details not finished yet but ready for some test runs. Let me know ill send the link.
    Added new programs
    New launcher.
    New walls
    cleaned up wall paper changer.
    Added wifi updates.
    added
    Es file
    Working Vevo
    Netflicks
    pluto
    Tv launcher
    Launcher 3
    Updated playstore
    Changed Boot animation..
    few other things.
    Need to test wifi /network speeds/wallpaper changer/Youtube playback 720/1080/4k /launchers/widgets and Antutu tests
    Let me know tried to change up few things because of not many options for the ddr4 version.
      Hi I can test the beta if you want thanks
        I'd like to test it as well.
          K just a few hickups ill send to you soon as its finished.
            Your rom works fine .. but i have some problem .. the restart option i do not see it, the flash app gives me the error, and supersu white screen. Can you tell me the procedure for flashing the Rom? thank you
              Download the rom and just follow this procedure.
              The reset pin on the h96 is small hole on side.
              For restart just use reboot apk that is on playstore by pergus.
                Ok ill send link soon as its finished uploading.
                  Sent it. You both should have it now.
                    Works good so far. It did just like you said.
                    Youtube app and wifi no problems.
                    Do you plan to keep the stock UI look or do you plan to use another one?
                      There 3 launchers and wallpaper apk. Iam trying different ui now but heat back. The firmware has stock launcher/tv launcher/launcher 3 . i think ill make all of them non system so anyone can remove if not wanted. I personally like Tv launcher just because You can customize bit more then the others. Boot up after first boot much faster now and added somemore apks. With the 3/32 its not wasted space
                        I think I like launcher3 best.
                          Think i find issue. Can you try left click hold in browser see if you can download any image? Think might have few issues still to work out.
                            No problems L-click holding in browser, everything downloads fine.
                              Hi, I have this problem: if you try to restart the bootloader, the device restarts just as it is located on the main screen and turns off the device itself. Can you check it out? thank
                                Yes fixed. I post new link tomorrow. Just want to test it ob mine for a night.
