and yes, my box also has 2 extra USB ports hidden inside the box, I found it out when I opened the box.
Alfwise H96 Pro Plus DDR4 version
Hi, I have the exact same box from 4K, H96 Pro Plus 3GB/32GB, DDR4 (as it says on the label when I opened the box), I need to know if anyone has the related Android 7.1.1 firmware for this box? I have tried a couple posted on some youtube links and some other sites but non of them appears to work with my box (possibly those firmware are DDR3), if anyone has a working firmware for DDR4 model please do share,
use scooter2014`s debloated firmware (works fine for me) or
supercelerons version with missing wifi driver and not working remote.
(if you need, fix the wifi (if you use LAN, you are fine) and fix the remote by reading this forum. if u have an external remote, like rii 28 with usb dongle, you are lucky and you dont need the remot fix)
but it is android 6 and i havent read about a 7th version, yet.
what is bad with android6 and why do you need android 7?
Have already read all about the firmware you mentioned, and since 7.1.1 is the latest it'll have better security/performance etc... So why not try it, just am waiting for a DDR 4 firmware, can someone guide me from where I can find the factory image or firmware for amlogic devices? Is there a platform/site available with all amlogic supported devices firmware?
found this link: http://chinagadgetsreviews.blogspot....+s912x&x=0&y=0
not sure if it is a generic firmware for all s912 boxes and if it is DDR4?
I have Alfwise H96 Pro Plus DDR4 version 32go 9377 Wifi
I want to use Burn Card Maker
What are the options to check "Burn Card Maker" to flash firmware?
Is it correct the option?
[x] To Partition and Format.
[x] erase_bootloader
[x] erase_flash
[forcefully erase all]
[x] reboot
I found different tutorials, there are different options selected, please give me the one that is correct:
http://freaktab.com/forum/tv-player-...509#post640509
or
http://freaktab.com/forum/tv-player-...278#post621278
Sorry my english is bad
Thanks advance
AlfaWise H96 PRO+ DDR4 / 32go
Just want to add myself to the list of successes. Lol
I own the ddr4 version (generic 4k branding 3/32g) and have successfully flashed supercelerons scv1 for ddr4 rom via the SD card route plus the 9377 wifi fix and fixed the remote. Happy camper here!
Thank yousuperceleron and scooter2014 !
I have read the threads and most say they are very interesting. I am new to this particular box and have a question. Mine has the 3g and 32gb DDR4 Ram as stated here but I have a issue with the 5g wifi connection. The box has both 2.4 and 5 ghz connection and the 2.4 works perfectly well. However, the 5ghz will only work if I disable the 2.4 ghz on my router which obviously I can not because most of my other gadgets use 2.4ghz. With 2.4 and 5 ghz switched on at my router, the box states it can not connect. Is this an issue others have experienced and if so, what can be done about it? Thanks
Originally posted by dudger76 View PostYou are flashing the ATV (Android TV) Wi-Fi fix over the standard SC firmware. Download the Wi-Fi fix for the standard version.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by Kevin Flynn View PostGreetings everyone.
I recently purchased a few Alfawise H96 Pro + 3GB/32GB boxes from gearbest.com and they arrived just a few days ago, and I got them all setup without too many issues, but it appears I am in need of a firmware upgrade, because I have the problem where power off hangs, and refuses to power back on. The first box of this type I purchased from Amazon, and its not an Alfwawise model, but rather the "4K Ultra HD TV BOX" style, and it's power on/off functions normally as it should.
Reading some other posts, seems to suggest there are multple versions of this Alfawise box, the main difference apparently being a DDR3 version, and a DDR4 version. Not knowing which ones I owned, and having to open one up to find out, I went ahead and documented everything as best I could in regards to exactly what gearbest.com shipped me, so I thought I would post all the info here in order to share it with everyone. I'm new to these forums, so if I'm posting this to the wrong place, by all means, please forgive me.
Heres a run down of all the information I have on this unit so far:
Product Information
Alfawise H96 Pro +
S912 8 core 3GB / 32GB / US Plug
Gearbest.com Product Page: http://www.gearbest.com/tv-box-mini-pc/pp_503486.html
Price paid: $69.99 each, flash sale, ymmv
Delivered in < 1 week to US residential address, ymmv
Board Information
Top ( CPU heatsink side )
Solder Mask Text
Near Gigabit Ethernet Port: QL 1708
Just above CPU heatsink: 2017-02-10
H96-S912-TVBOX(DDR4)-V0.2
Bottom
Small label
3G+32G+9377
21070321
Large Label
Wired Ethernet MAC address ( blacked out )
OUI: MAC begins with 78:C2:C0
http://macvendors.co/results/78:C2:C0 = IEEE REGISTRATION AUTHORITY
Chip Information
Top
C1 - RTL8211F
GB1F3H2
GG49
10/100/1000 Ethernet Transceiver
C2 - Pulse
H5007NL
1650-M CHINA
1000BASE-T Magnetics Module
C3 - BIJY
PPE13
SS
7C20
??? Unknown, maybe DDR4 ?
C4 - 9P9V
PPE13
SS
7C20
C5 - Fn-Link
8223A-SR
F01019
1703
WiFi Dual-band 1X1 11ac + Bluetooth V4.1
C6 - R03242
1316KAE
JAPAN
THGBM5G8
A8JBA4X
Appears to be 32G Flash Chip
Part #: THGBM5G8A4JBAIM. Description: Semiconductor & Storage Products Company. File Size: 200.6 Kbytes. Manufacturer: Toshiba Semiconductor.
Bottom
C7 - FC65
PP026-093E DG
C8 - F5T1
PP026-093E DG
C9 - GL850G
HH4JB05Y22
646SFX3921
USB 2.0 HUB Controller
Part #: GL850G. Description: USB 2.0 HUB Controller. File Size: 314.05 Kbytes. Manufacturer: GENESYS LOGIC.
C10 - DIO2133
1707
F1
3-Vrms Audio Driver with Adjustable Gain
Android OS Information
Settings -> Device -> About
Device Name: H96 PRO+
Model: H96 PRO+
Android Security Patch Level: August 1st, 2016
Version: 6.0.1
Serial number: 2016????????
Build: MHC19J.20170327 test-keys
Settings -> More Setttings -> About MediaBox
Kernel version: 3.14.29
mly@czkj #4
Mon Mar 27 18:49:02 CST 2017
Hopefully this information can help others identify which device they have, so that they too can update their firmware.
@chenrp
please open the cliped on cover, and remove the paper sticker on the pcb. (no need to use a screewdriver!)
normaly it is printed on the pcb. if not, check the number on the ram chip, and google it.
but this info is not interesting more.
the new roms are working on both boxes...
use SCV4 and above
There are currently 3540 users online. 1 members and 3539 guests.
