MOV Z69 2GB RAM 16GB ROM rooted firmware?
but in my case i take safety pin and swap it from left to rite on my mentioned yellow line while connected my device on my pc through usb male to male cable on my device otg port and running usb burning tool started.
firmware Z69 2gb/16 download :
https://onedrive.live.com/?cid=46126...HrjCagwVd3kcRM
Think he confused as none 8/9 doesnt exsist.
NICE ADD TO NAN THREAD LOL NOW I CHECK 3/32Last edited by scooter2014; 15 September 2017, 01:53.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
I can not do anything. light blue and red! the part that speaks of pins 8 and 9 I am in doubt if I remove the pin or if I make contact with the 2 pins. Could anyone help me?
in the image above it looks like pin 9 has been removed and then connects with pin 8 will it?
i´m conect box to pc via otg cable usb and pc not recognize. i´m open usb burning tool conect box with usb cable and press reset button and nothing happens.Last edited by Paletas69; 17 September 2017, 00:16.
Originally posted by Paletas69 View PostI need help.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by Paletas69 View Postthank you guys! I unlocked the box but the problem remains must be box breakdown. it freezes and hangs constantly.
but I already contacted the gearbest and they returned the money and I was stuck. Does anyone have any idea what the malfunction might be?
Good luck!
Its software related. Having a bit of issue getting time to finish 6 rom. But got it at least running smoother going to try few other things but once the devs get a similar base rom that dosnt look at ram config as the 3 gig model wont run any of the stock or custom 2 gig firmware so kinda in a nich that not much out thrre yet. Hope better firmware coming from manufacture. I dont have the 2 gig device but if i did id be trying the firmware for those devices to find best one. But cant test what i dont have.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by digitalriver View PostSo. Finally I turned on the bluetooth on last xtmod firmware(XTMOD_EX_P_27bis).
https://mega.nz/#!z9dgDQBQ!kg_mKeOYT...EyfhLh1Dmw0OoQ
These files you must put to correct folders with correct permissions.
All works fine, sound transmission is not breaking, mobile phone connecting, file transmit working
P.S When you replacing libhardware.so and libhardware_legacy.so - the box is restarting. dont worry its ok
Edit : While reading further in the thread I discovered my question was already asked and answered.
Has anyone tried this mod on other ROM's ?
Yes, I know, this was my postThis fix for XannyTech firmwares, and I dont know, if this scheme works in other roms. So:
Permissions: all folders must be 755, all files - 644.
Destination:
app - must move with replacing to:/system/
etc - must move with replacing to:/system/
lib - must move with replacing to:/system/
I think it's not very difficult?)) for correct moving you must use correct explorer with root accses, for example - ES Explorer PRO(with enabled ROOT in his settings). I recommend move folders in course.
1. First move "app" with content. Check moving, check and(or) change permissions of files and folders.
2. Second step - move "etc" with content. Check moving, check or change permissions of files and folders.
3 Third step - move "lib":
3.1. first move "hw" and "rtkbt" folders with content, check moving, check or change permissions of files and folders.
3.2. And last step: move only files in "lib", because when you moving libhardware.so - the box go to restart.
3.3. After restarting change permissions of files from last step, restart againe and try to enable bluetooth
There are currently 2911 users online. 1 members and 2910 guests.
