X96 unbranded firmware with some fixes
Originally posted by Downunder 35m View Post下載 Beta 5
使用 Winrar, 提取到sdcard.
帶牙籤的啟動盒.
TWRP 有中文.
看看怎麼用TWRP在中文網站上.
Use my Beta 5.
Extract with Winrar to SDcard.
Boot box with toothpick.
TWRP supports chinese.
Check how to use TWRP on chinese website - wipe, install, reboot.
Downunder 35m我在论坛下载了rom,然后用PC刷机取得,或者非常感谢你.beta 5 is not right.I Fan a mistake, x96 no ROOT on the brush machine. But what about ROOT?Last edited by yetian; 28 May 2017, 23:59.
Originally posted by Downunder 35m View PostIf you get ERROR 7 when installing:
Remove line 1 and line 2 from updater script inside Meta-info folder.
You need to unzip for this and pack again as ZIP.
After this it will install.
After this it will install.Last edited by yetian; 29 May 2017, 06:11.
Root does not change the memory.
For the update script:
Unpack the Zip Archive.
You will find this:
META-INF - folder with script
boot.img - file
bootloader.img - file
dtb-img - file
file_context - file
logo.img - file
recovery.img - file
system.new.dat - file, big
system.patch.dat - file
system.transfer.list - file
Inside META-INF folder:
com - folder, rest ignore.
Keep opening com folder and see:
android - folder
google - folder, keep opening this folder!
android - again open folder!
update-binary - ignore!
updater-script - edit this file with Notepad++
Remove the first two lines.
With first two line gone the updater-script start like this:
ota_zip_check();
set_bootloader_env("upgrade_step", "3");
show_progress(0.500000, 0);
Zip all files again and you can update.
Like that the script will ignore all checks for correct hardware and just install firmware.
If you like use the Beta 3.
You will find this:
boot.img - file
dtb-img - file
file_context - file
logo.img - file
recovery.img - file
android - folder
ota_zip_check();
Originally posted by Downunder 35m View PostTWRP is already included in the RAR archive, so no need to search for one
And yes, UBS stick works fine too, just use the port closest to the front of the box.
Takes a few seconds longer to boot into recovery but works fine.
There are currently 3180 users online. 1 members and 3179 guests.
