And the remote functions remain like the original, just the WiFi keyboards got some fixes.
X96 unbranded firmware with some fixes
well thanks once again, I cant get it to flash though
downloaded thesaid files, extract the recovery.img and x96-1gb to usb
tried with tootpick into android recovery, some error
tried to reboot into revovery via a reboot app, no twrp
I must be doing something wrong, any ideas?
heres a link to a pic n my google drive https://drive.google.com/file/d/0B-V...ew?usp=sharing
thanksLast edited by moiloon; 31 May 2017, 17:46.
how can I have my box like the one in the video on the 1st post?
I wish mine to be like that, but all the betas ive flashed remain like the original rom, other than apps ect removed/replaced
thanks
edit- another flash of beta 3 seems to be the only one that seems to be correct on my box, god knows why lolLast edited by moiloon; 01 June 2017, 20:53.
Originally posted by Downunder 35m View PostJust download the archive and follow the insrtuctions posted a few times.
Always the same, unpack to SD card, plug in and boot with a toothpick.
From there just select the file you need in TWRP and flash it.
when i open it as txt it only shows one long line, shoud i delet everything up the the second ;
thanksLast edited by mhernandorena; 09 July 2017, 06:24.
Use Notepadd++
With it you can see what matters and save the file correctly.
A normal text editor just doesn't cut it here
But before you do that you should be aware that this disable any safety in case yourdevice is not a genuine X96.
A different device might not work correctly with this firmware or fail to boot at all.Last edited by Downunder 35m; 09 July 2017, 08:41.
Originally posted by Downunder 35m View PostUse Notepadd++
With it you can see what matters and asve the file correctly.
i've tried everything now it tells me:
failed to mount this or that
or still gives me error 7
and also could not find 'meta-inf/comgoogle/android/update-binary
but i see the file in the zipLast edited by mhernandorena; 09 July 2017, 08:43.
There are currently 1579 users online. 0 members and 1579 guests.
