Many thks to gearbest for sending me the device to play
Many Thks to my beta testers trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Changelog Beta V1:
- Based on stock
- General optimization.
- Fixed emmc cache/system mount problem!
- Fixed All video playback ( Youtube included )
- ADB fixed, network and cable.
- Added power button to navigation bar, single press = sleep, long press power menu.
- App switch moved the close all open apps to the right
- Hide navigation bar now also hides upper taskbar, so dont show anymore on Youtube and other apps!
- Proper root! (Dont forget to update su binary )
- Organized some boot scripts.
- Added lots of kl's.
- Custom Wetek WebOs launcher (Many thks to wetek for let me use it)
- - Menu Button is king on this launcher, its used to add remove icons on the main screen, also to remove widgets.
- - Long press on the default icons on desktop you can change them to other apps (White Logos...)
- - Long press on the icons you add to the deskop and you can rearrange them.
- Live Wallpapers, From Android TV ( Read Tweaks Section on how to enable it )
- Android TV remote control! ( download the app from playstore to your phone )
- Netflix, youtube, playstore...etc... fully working ( No 4k Youtube, that is exclusive of Android TV roms )
- initd.d support.
- Xbox360 Gamepad Wired and Wireless support.
- Gaps Updated
- Permissions fixed.
- Added Xposed Framework
- FTMC Build 26 ( Dont forget to enable ALL RKCodec stuff in settings )
- Permissive mode!
- Added a few apps...
- And some other little stuff...
- 1. Setting - Display - Daydream - ON - the upper right corner of the three points - When to daydream - While charging.
- 2. Setting - Display - Daydream - select "Backdrop"
- 3. Setting - Display - Sleep - choose the time after which screen saver turns on.
- If Setting - Display - Daydream - OFF, after a specified time tv-box will go into standby mode
- Update SuperSu binary that will make the box boot faster!
Bugs Beta V1:
- Setup wizard dont start automatically it need to be manualy executed... ( check my youtube video )
- Setup wizard dont resize the screen to 100% even it it says it is... go to settings and resize.
- You may have a quick green screen at boot... nothing special ignore it!
- FTMC crashes playing H264 10bit files with RKCodec enabled, that is a problem of the lib in the firmware and not a FTMC problem.. not fixable for now, so plz if you want to use for read H264 10bits files disable RKCodec in settings.
- FTMC dont show the temperature, that is a bug in the kernel!
- Possible lot more Bugs...
Want to buy me a beer?Download:
- DOWNLOAD HERE SCV1-Beta for the Yundoo Y8
- MD5: 6357330BFBDF7B5CBE4DE54D05A874B1
- Search the forum for instructions!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
Here is a video of the rom:
