[ROM] Yundoo Y8 Android 6.0.1 - SCV1-Beta
Originally posted by dukekox View PostHey folks, will there be a recent update soon or should we stick to this SCV1-Beta for a bit longer. It would be just great, if there is a progress like on the S912 boxes. Thank you for all your work - you are making tv boxes great again ;-).
All A6 rom out there sucks and i mean all!
Originally posted by berdroid10 View Post#73
Não entendi
Superceleron
I did not understand. Go in settings? I can not connect the cable and I connect the pc and neither a signal happens, nor a sound recognition of the pc or anything. Gives me the impression that the cable type C is not working, I already tested 2 cables. Should I enable some configuration is this?
Dunno why but looks some of this boxes have this problem, you need luck to find a cable that works..
But that dont mean you dont have a HW problem on the box, it can also be that!
Superceleron
Understood.
Excuse me, I speak Portuguese and the translation sometimes gets difficult.
Thanks for the attention of the answers
Just tell me one thing.
As soon as you connect the yundoo to the PC through the usb type C it is already pro pc recognize the plug is not it?
Even without the drives that work just recognize
Or would you need my BOX to be powered on ??
Originally posted by berdroid10 View PostI did not understand. Go in settings? I can not connect the cable and I connect the pc and neither a signal happens, nor a sound recognition of the pc or anything. Gives me the impression that the cable type C is not working, I already tested 2 cables. Should I enable some configuration is this?
Just wanted to know if my C type input is faulty. Because I can not get any connection signal with pc to be able to update your rom
try it:
сhange in config.ini RKBatchTool/AndroidTool/etc.
SUPPORTLOWUSB=FALSE (SUPPORTLOWUSB=)
on
SUPPORTLOWUSB=TRUE
I'm using this ROM since the first days it was published and its working much better than the original one.
Thank you so much for your hard work superceleron. You really gave a new life to this box!
By the way, do you plan to do an update to the ROM with new bits and fixes?
Originally posted by PugnettaHi Superceleron now it's been months since you always repeat the same things you will make an update to this yundoo suck Y8 hope you will not pass years when it will be an old box ...!
Dont worry it wont take years to update it!
Hi superceleron. Yesterday I came back from holidays and my Yundoo Y8 was really hot. It didn't had any app running. Is there any way to fix this heating? When can you please update this box software? I know that you have a lot of ROMs to maintain and you do it as a hobby, but almost all the owners of the Yundoo depends of your firmware...
Thank you for the support!
Thank you superceleron.
By the way, I also want to report a bug not mentioned on the first post: I turn the box off (red led on) and then after some hours, it auto starts.
superceleron we all know that you have a LOT of ROMs to maintain, and you do it for free, but could you please update this ROM?
It's been already 4 months since its release and we're eager to get it more stable... Please, do not forget the Y8 :-)
Thank you so much for your efforts!
Originally posted by capelo View Postsuperceleron we all know that you have a LOT of ROMs to maintain, and you do it for free, but could you please update this ROM?
Olá! Superceleron
do you know why your rom does not accept any accessibility services?
the accessibility applications are downloaded and installed but can not be enabled in the Settings menu
do not access the settings / accessibility / services path.
you do not have the option to enable the service.
Where can I activate this?
There are currently 2273 users online. 1 members and 2272 guests.
