Type: TV Box System: Android 7.1 Processor: RK3328 CPU: Cortex A53 Core: Quad Core GPU: Mali-450 RAM: 2G RAM Type: DDR3 ROM: 16G Max. Extended Capacity: 64G |
Decoder Format: H.263,H.264,H.265,HD MPEG4 Video format: ASF,DAT,FLV,ISO,MKV,MOV,MPEG,MPG,TS,VOB,VP9,WMV Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,WAV,WMA Photo Format: BMP,GIF,JPEG,PNG,TIFF Support 5.1 Surround Sound Output: Yes |
Bluetooth: Bluetooth4.0 Power Supply: Charge Adapter Interface: AV,DC Power Port,HDMI,RJ45,USB2.0,USB3.0 Language: English,Germany,Japanese,Korean,Multi-language,Simplified Chinese DVD Support: No HDMI Version: 2.0 Other Functions: 3D Games,3D Video,DLNA,Miracast External Subtitle Supported: No HDMI Function: HDCP Power Comsumption: 10W RJ45 Port Speed: 100M |
System Bit: 64Bit WiFi Chip: 8723 System Activation: Yes |
Power Type: External Power Adapter Mode |
Product weight: 0.2000 kg Package weight: 0.5100 kg Product size (L x W x H): 14.00 x 9.00 x 2.00 cm / 5.51 x 3.54 x 0.79 inches Package size (L x W x H): 16.80 x 12.40 x 7.50 cm / 6.61 x 4.88 x 2.95 inches |
Package Contents: 1 x MX9 PRO TV Box, 1 x HDMI Cable, 1 x English User Manual, 1 x Remote Control, 1 x Power Adapter |
MX9 PRO RK3328, Android 7 2/16GB WiFi, Fast Lan BT4
GearbestLast edited by trebor; 17 August 2017, 01:18.Tags: None
I received It yesterday. I have to test it. I noticed that there is no notification bar (the top one) and not even the navigation bar (the bottom one). How can I enable them? I went to the menu but did not find the right voice. Gearbest told me that It's rooted, but I still have not found an application that works to control the root presence.
Originally posted by MX9Pro View PostWhere can I download firmware ? thanks.
It's the same as the mx9 pro ....
G'day All
Another day and yes another Media player to feast your eyes on the MX9 PRO RK3328, Android 7 2/16GB WiFi, Fast Lan BT4
Let's not wander around like a Wallababy on a walkabout me old onions let's have a ganda.
The box, Kicked from China to AU by the Socceroos by the looks
Inside the box and contents OK, a bit of a looker this Unit
Ports, note smaller HMDI Port. cable is supplied
Topside of PCBClick for larger
UndersideClick for larger
Wifi Chip
Base and Lid of Unit
More to come as we fire it up and see what it has to offer.Last edited by trebor; 30 August 2017, 20:53.
Onto some testing and Information etc
Switch on Good, no problems with Google, set up apps, updated no weird stuff
Remote, feels good, purple Buttons wife likes, works well.
Good looking Unit I feel different shape has the look The Wedge comes to mind
Being a Rk3328 CPU, good for streaming and social games not a big performer.
2.4Ghz wifi and Fast lan, BT handy for speakers, keyboards headset etc.
In Images above we see Samsung Ram and eMMC so speed should be Ok to Good.
Box warm to touch heatsink ok..Bigger would be better I feel.
Unusual to see smaller HDMI port on this Unit small is good, also smaller OTG port
Youtube 1080
Netflix, lipsync problem change to 24hz ok, picture looks good not HD but ok.
We do have Root
Don't update SU or it will have boot loop...
No upper notification or lower task bar.
Lets have a look see
UI, looks ok simple clean
Installed apps
Drm Information L3
Ram and Storage truth
CPU-Z
Youtube
Netflix
Geekbench Compute and CPU
More Info > http://browser.geekbench.com/v4/cpu/3844322
A1SD Bench not to bad
Not a bad Looking and performing ok for what it isLast edited by trebor; 30 August 2017, 20:44.
Hi Trebor...I just got this box and updated the supersu before seeing your post here and it's stuck on booting...So with the searches I've done I found this page and have downloaded the RK Driver Assistant and RK Batch Tool and have plugged my box into usb on my laptop. I downloaded the firmware file as well. I ran the installer for the drivers (I'm running windows 10) says installed okay. Then I open the RK Batch Tool, load the firmware then plugged in the box to the laptop while holding a paperclip on the reset button but my Device does not get Detected in RK Batch Tool...I've been trying for many hours all different ways to load the box but I can't seem to get it to load or detect my device. Would you have any suggestions as to what I may have to do to get it to detect my device?
Thank you for any help you may provide...Aaron
This rom I installed but no Bluetooth 4.0
http://freaktab.com/forum/tv-player-...1-beta-version
Originally posted by tatr999 View PostHi Trebor...I just got this box and updated the supersu before seeing your post here and it's stuck on booting...So with the searches I've done I found this page and have downloaded the RK Driver Assistant and RK Batch Tool and have plugged my box into usb on my laptop. I downloaded the firmware file as well. I ran the installer for the drivers (I'm running windows 10) says installed okay. Then I open the RK Batch Tool, load the firmware then plugged in the box to the laptop while holding a paperclip on the reset button but my Device does not get Detected in RK Batch Tool...I've been trying for many hours all different ways to load the box but I can't seem to get it to load or detect my device. Would you have any suggestions as to what I may have to do to get it to detect my device?
Hold Button plug in usb, mine detected in an instant,
Unless not enough power at usb port ?
Check device manage on PC maybe unknown device, just remove from device manager and rescan may detect ok.
Using win10 here..
Originally posted by trebor View Post
You are using OTG port small one...
Using win10 here..
Thank you for trying to help but I may just leave it for a bit and see if newer files come about that I can try later on because I'm getting really frustrated with this box. I've spent about 20 hours trying to get this out of the boot loop with no luck at all.
Thank you...Aaron Raymond
There are currently 2733 users online. 0 members and 2733 guests.
