MX9 PRO RK3328, Android 7 2/16GB WiFi, Fast Lan BT4
Originally posted by Fuzo View PostI forgot to mention one thing, Wi/Fi is not working after recovery, tried 2 different firmwares, when I turn it on, it turns off after a few seconds. I found some tutorials how to repair it but the device has to be rooted and I have to delete one file in root directory, but I don't know how to do it. Anyone any idea?
Originally posted by dijomi View Post
Fuzo how to fix wi fi to work.I have MX9 pro 4\32 and repair firmwar wi fi not work.
does your Box use a different Wifichip ??? wich one ???
maybe it works with "init.d" or similar , running a script after boot that has the
correct Wifidrivers , but you need root and knowledge , or a Dev , can or will
make this for you ??? I am not able to do this .
hope this helps
greetings / gefattern
Hi ,
hope this helps
Hi my wifichip is AP6255.But these rom's are not for this chip?
for working Wifi you need the StockRom for your MX9Pro 4/32 , maybe the Company
used another Wifichip for the 4/32 Model .
Maybe User Trebor can help he has this Box (i think) because of Review he made ,
he can make a Backup of the StockRom and upload (if he want) ,
You can ask "Gearbest" too , maybe they can help ???
good luck / greetings / gefattern
[QUOTE = gefattern; n717731]
Здравейте,
за работа Wifi имате нужда от StockRom за вашето MX9Pro 4/32, може би компанията
използва друга Wifichip за модела 4/32.
Може би User Trebor може да помогне да има този Box (мисля), защото той направи преглед,
той може да направи резервно копие на StockRom и качване (ако иска),
можете да попитате "Gearbest" също, може би те могат да помогнат ???
на добър час / поздравления / gefattern [/ цитат]
Здравейте gefattern благодаря за съветите и коментират .Yes моля, ако някой разполага с телевизор кутия MX9 про 4 \ 32 е WIFI чип AP6255, може да се направи резервно копие на StockRom и качване (ако искате) . Благодаря ви предварително!
Originally posted by trebor View PostExcellent, to see.
Good it all worked out, myself yet to test Rom,
It was defaulting to 720p (DELL u2718q monitor) and manually switching to 3840x2160 60Hz would not work, just black screen or some degraded graphics and glitching.
Anyway I finally tried to get it back to stock after finding the no wifi issue with all the other firmware options, and now still have broken wifi using this rom [a9s_rk3328_d4_rtl8723_20180115_r1(mx9pro 无插件).img]
Sooooo, my current issue list is
No Wifi
No 4k output (will try different monitor later on today)
Has the default firmware been made available yet or can someone save theirs? (wishing I'd shown due diligence and saved mine before wading in and flashing others)
Cheers
Oh, 4GB/32GB model
There are currently 2132 users online. 1 members and 2131 guests.
