MX9 PRO RK3328, Android 7 2/16GB WiFi, Fast Lan BT4
Originally posted by Artredis View Post
Hi all! Right now I have a new problem. The power button lights solid red (like when it is turned off), but I cannot turn on. If i push the button or try to turn on with the remote, nothing happens. Any idea what can be the solution?
Originally posted by Fuzo View Post
You probably need to flash new firmware, because the device seems to be bricked. Here on this forum are some tools and tutorials how to do it. If you will have some issues to connect to the PC, try MASKROM mode, worked for me.
EDIT: Now I tried to power it from the OTG USB port and now everything works perfectly. Now i guess my power brick died.
Thank you very much. I flashed the new firmware with the RKBatchTool. It said everything went succesfully, but now when i plug it back, the power button flashes red for a few times very rapidly and then nothing happens
As Found Not tested
MX9 PRO ANDROID 7.1.1 RK3328 4GB/32GB TV BOX FIRMWARE UPDATE 20180115
Glad to share the firmware for MX9 PRO TV Box
PC Flash Firmware
http://geekbuying.mediafire.com/file...k3328_20180115
Source:blog.geekbuying
Looks like they for got the extension .zip on this file
rename it Rk3328_20180115.zip
Then extract you will get image fileLast edited by trebor; 14 March 2018, 22:34.
There are currently 2523 users online. 0 members and 2523 guests.
