Thanks!
Freelander PD800 RileyROM 1.2 [Feedback]
Sadly, I'm really busy today...it will have to be Saturday.Randy
I knew there was one thing I forgot to do Saturday. I spent all day getting my new laptop going.
I'm looking at that ROM.
STAY TUNED.
RandyRandy
OK, I think I found a possible problem in the parameter files.
Take your pick of which parameter file you want to flash.
Open it in notepad.
The next to the last parameter is (system).
Change the number 168000 to 102000
Save the file and flash the ROM.
See if that fixes the problem and report.
I'm uploading v1.2b with these changes.Randy
Originally posted by rrileypm View PostOK, I think I found a possible problem in the parameter files.
Open it in notepad.
Thanks again!
HAHAHA!!!
You are like me...having more time at work to flash ROM's!!!!!!Randy
The upload of v1.2b is finished.
Just follow the link in post #1. Since v1.2 didn't work, I just took that link down and changed it to 1.2b.Randy
Update: Ok....so 1.2a with corrected parameter file created in Notepad got me back to the boot screen.
Man!!!!
I thought I had that fixed this time....back to the drawing board.....Randy
Update: I did all the Google/Android updates it requested...still good.
Is it possible an app or service is causing this to freeze up? I'm on about a dozen reboots....smooth sailing so far with only your stock apps and the requested updates. Haven't downloaded or installed anything else.
Success???!!!!
Ok...so I used the 1.2a download and the 8gb parameter file modified in notepad as you suggested. So far after heavy use this morning I'm happy to report no issues. I've power cycled while plugged in to USB, AC every possible configuration with not a single problem. I've downloaded 1.5gb of apps all on the internal storage and did not share to the SD side to save room. Fingers crossed you've got this one nailed
Originally posted by circusboy View PostOk...so I used the 1.2a download and the 8gb parameter file modified in notepad as you suggested. So far after heavy use this morning I'm happy to report no issues. I've power cycled while plugged in to USB, AC every possible configuration with not a single problem. I've downloaded 1.5gb of apps all on the internal storage and did not share to the SD side to save room. Fingers crossed you've got this one nailed
And we lasted all day...but....tried to download Dungeon Hunter 4 when I got home...and she froze up. Back to being stuck on RileyRom Badge spalsh screen.
It's something in the parameter files. If I use 1.2a with parameter files modified by myself in notepad...it works...for a while. If I use 1.2a with the new parameter files you provided in 1.2b...no dice.
UPDATE:::: I can officially confirm Dungeon Hunter 4 causes the system to crash and freeze forcing you to do a hard reset which gets you stuck on the splash page. (tried it 3 times). The file size is 957mb...which is suspiciously close to the original/stock SD allocation for apps. I tried another game that was 1gb with same result...must be something with these large file sizes. Thoughts???
Let me upload another experiment with a different set of parameter files to test.
It will be 1.2c.
I will post a link as soon as it's done uploading.Randy
There are currently 2069 users online. 0 members and 2069 guests.
