MK806 NEOTV CROM 1.0 20130730 by Neomode
    It was the cable!
    Thanks to you primer and neomode.
    Phwee, Neomode was right: it was the cable!
    Now I am back home and should be able to make deeper testing in the coming days.
    I realized that it do not recognized my apple bt mouse as opposed to the default rom
    but it is not important for me.
    I am really eager to install and try different apps that did not work with the default rom.
    Thanks again for your rom Neomode!
      surprise!! (You're on candid camera!
      Wow,
      Could never expect that software crashes due a cable, it seems critical to just one app?
      How the F... did Neomode expect that?
        AW: MK806 NEOTV CROM 1.0 20130730 by Neomode
        How? I have a lot of experience with this devices. I also know where the most problems are :-)
        No Magic :-)
        Neomode
          PUZZLES
          Originally posted by neomode View Post
          No Magic :-)
          Well respect anyway, can learn a lot from that I guess.
          As for yr information
          I ordered myself another mk-806.
          hope I can retreive firmware from this one, flash it into the non-good one,
          (at least when they are the same)
          Otherwise I can play Radio on my audio gear again.
          and use the no-good unit as a sort of experimental gadget to flashed forward and backward
          maybe bricking it, but as it was no-good anyways. No prob!.
          Will be going to Italien, durch Deutschland and back also through Germany,
          stops to be made :
          Kevelaer, Freiburg im Breisgau, zuruck Eppelstein, Übersee, Wolfstein and Morbach.
          Not especially to be in this order. Sorry!
          Cheerz
          drinking Kirner Weizen.(the picture being not so realistic in color)
            Indeed, you seem to know where you are going.
            I've install all my basic apps and right now everything run smoothly. Tomorrow I will install what was bugging my device with the old firmware.
            I was wondering if we can play with the mk806 audio driver like we can do with alsa driver. I would like to crank the amp volume to the max...?
            @primer: have a good "drinking" trip!
              beers/wines and spirits (a litte off-topic)
              Thanks a lot,
              As this Italy trip is somewhat new to me I need yr support.
              So thx again!
              cheerz
                Gosh!!! I was hoping this rom would help me with the USB joystick center app, but unfortunately it's doing the exact same: as soon as I hit the "create driver" bouton, the system freeze. With my other rk3066 stick, it is working fine...
                  A new star has risen!
                  Yo, I got the new MK806.
                  and I tested it for wifi and for sound,
                  both seem OK.
                  Checked the flash programs, but I cannot find a rom-dump feature,
                  and be able to restore that dump into the broken one.
                  Can I do this by titanium backup?
                  but booting in recovery mode will leave me without the volume up-down keys and acknoledge.
                  Can you advise me?
                    Fixed this issue!
                    Originally posted by primer View Post
                    Can you advise me?
                    Well, I'm happy.
                    No advise needed anymore so far.
                    I found the solution.
                    It took me 3 nights puzzeling and searching, and getting always the same answers, which did not work
                    but a change in searchstring gave me a real good search result.
                    So I now have 2 identical working MK-806 units.
                    One for serious business and 1 for testing for more functionality or whatever!!
                    Will drink Paulaner Weizen on it.
                    Ciaoooo
                      Bluetooth not working
                      Hello Neomode,
                      i flash this Rom but i can not activate the bluetooh . When i click on the buttom to activate it, it will try to star it but nothing comes up. Have you a new Rom or and fix for this. I have the Stick MK 806 with Bluetooth/ Wifi and conection for earphones . The Chip for Wifi is RK 903
                      Regards Eddi
                        Hello,
                        Can you send me the output of dmesg please?
                        To do this install terminal emulator and then run it and type
                        su
                        dmesg > /sdcard/dmesg.txt
                          Dmesg
                          Hello,
                          i send it to your mailadress. Regards
                            Good Morning Neomode ,
                            did you find something what happend with the bluetooth problem ?
                            I hope you have time for this and an idea ;-)
                              Did anyone figure out why Neomode's rom disabled bluetooth and/or wifi on some MK806's? Was it a result of different chips being used despite the same model name?
                              I've been thinking of getting an MK806 because of the headphone port. I currently use a Uhost2 connected to a Motorola Lapdock, which I love. But to get a headphone out, I have to use a USB sound card which takes too much power often, and otherwise provides a LOT of hiss and noise from the device.
                              At this point, would it be a bad idea to buy one of these? My RK3188 device requires too much power to be run directly from a lapdock - and I kept getting screen errors. So I was hoping an MK806 would be a good match for my device, and a lateral "upgrade" from the Uhost2. That said - the Uhost2 has excellent firmware, so I'd rather not get a buggy device.
                                Of course don't expect wolfson dac chipset. I find there is considerably background noise with my sound system but perhaps it is more comfortable with a pair of headphones. I don't use headphone with it. I would personally like to have a place on the rom to control the driver amp volume since with some of my apps it gets too low.
                                But overall it gets the job done.
                                Can't tell for others.
