It's always worked for me.
Pipo M8 Pro 4.2.2 RileyROM 1.9 Multi-Window [Feedback]
So...you are saying it won't work if you rename them without the txt extension? i.e..."parameter"?
It's always worked for me.Randy
Originally posted by rrileypm View PostSo...you are saying it won't work if you rename them without the txt extension? i.e..."parameter"?
You see five txt files and one parameter2 file. And thats the problem I think. The parameter.txt was origianaly parameter4.txt. Since I don't know how the default file is named "parameter.???" it stays a txt after renaming it.
Originally posted by Starcopy View PostCorrect. I've made a screenshot so perhaps it shows you what I mean.
[ATTACH=CONFIG]2844[/ATTACH]
Please forgive me for taking for granted what I consider to be simple things...I think I will start removing the txt extensions from the files...like 900Supersport and Finless do to eliminate further confusion.
With all I do to make a ROM, in order to save time...I got lazy and decided to let the users remove the txt extensions themselves...MY BAD!!!!!! Sorry for that.Randy
I'm not sure exactly what you are asking.
You can open any app within a window. From what I can tell, you can't resize the window (unless someone has figured it out). You can have 4 apps running simultaneously, taking 1/4th of the screen each...or you can tile them in the middle of the screen.
Watching videos in a window while doing something else is handy. But I still haven't figured out...or wonder if you can have one app full screen with another little window on top...or is that asking too much? Anyway, it's fun to play with, but the text is so small in a window, that you can't really use it to surf. My fingers are too big to hit the links...and my eyes are too old to see it very well even with glasses on.
Another thing I haven't figured out is how to make an app go back to full screen after you have placed it into a window. I have had to close the app in order to get it back in full screen.Randy
You can resize any window, just drag three fingers on it, the window will be greyed, then just pinch in with two fingers to adjust the size, till full size if you want (the blue border disappears then). and finish by grabbing three fingers to have it ready
You can have then a big window but overlapped over the others
Originally posted by Firestar View PostAbout the multiwindow functionality, are the gallery and settings the only ones with it implemented? I refer to the center-swype-down-window of the homescreen.
android:allowHalfScreen="true" need to be in the manifest as example (I have two versions of gallery2, one goes to this bar, the other not)
So Pipo or others must do this before we can have more app in this center notification bar;
Originally posted by rrileypm View PostJust power off and remove the external SD.
Power back on.
Go to settings...storage
Mount internal NAND.
You will get a notification that says damaged storage.
Touch the notification and select format.
This will set up your internal storage.
Having to do this process is a side effect of running CWM recovery in place of stock recovery...which does it automatically.
Sent from my M5
I had googled this and got a lot of 'non-answers'.
Again ...kudos!Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by rrileypm View PostThat is one of the limitations from Windows you just have to overcome...even though the extension isn't hilighted when you click rename...you can still scroll the arrow key to remove the .txt from the file name, manually. Windows will give you an error that warns you that the file may act differently if you change the extension. Actually WE WANT the file to act differently, so just go ahead and do it. You will end up with a file that is named "parameter" without an extension...then you are good to go.
There is nothing to forgive, if I had been using my head then this wouldn't have happend.
But I did what you suggested and it worked like a charm.
Fantastic!!!!!!!
You had me worried that none of my parameter files were working....Randy
I keep trying to reproduce that problem...but I haven't seen it yet.Randy
Originally posted by rrileypm View PostI keep trying to reproduce that problem...but I haven't seen it yet.
Maybe its a problem of my device.
same issue
Originally posted by Firestar View PostAnother observation, I cant switch between applications using the background APP button, I must go to homescreen first and then I can switch to another background application.
hi i have same issue and i post know 3 times and i send private massage but till know no body answare to this problem it is very important becuse every time i hvae to go back to homescreen
please some body can fix this issue?
There are currently 2092 users online. 0 members and 2092 guests.
