Pipo M8 Pro 4.2.2 RileyROM 1.9 Multi-Window [Feedback]
shajar...I really haven't been ignoring your problem...I just haven't been able to reproduce it on my tablet.
After running several apps, whenever I bring up the app switch screen mine goes to whichever app I select...it doesn't lock up or malfunction at all. I'm still trying to make mine mess up. I have no clue as to what might be causing it.
Remind me...are you running the wifi or 3g ROM?
Did you have the same problem with 1.8?Randy
replay to your questions
Originally posted by rrileypm View Postshajar...I really haven't been ignoring your problem...I just haven't been able to reproduce it on my tablet.
i have non 3g version
and same problem with 1.8
and there are 2 person in forum they have same problem also so it is not only me you can ask them also
Originally posted by shajar View Postthanks for your kind fast replay regarding to your question:
I use the chinese ROM#171 (verion 1.8 based on it) I have the same problem
The solution with the stock launcher is to click on home, then on Last application List icon and then whatever application you choose on the list it's OK, it will be opened.
With the Pipo launcher only the last one is launched, so I will ask Pipo to do something (I hope so)
In fact, when multi windons is on, the problem seems to be gone away.
do you have multi Windows off ?
Sounds good. Looks like it isn't quite perfected.
RandyRandy
your are exactly right
hi thanks for your replay
i hope pipo do smething becuse it is not good but if as you told if i turne on multi windows on it will solve the problem but if off then it will not react on appiciation that you use
so what we shall do? wait and see? or go back to 1.7?
Re: Pipo M8 Pro 4.2.2 RileyROM 1.9 Multi-Window [Feedback]
If your tablet is acting up with this ROM...by all means...feel free to flash back to 1.7. If it is more stable for you.
I am keeping 1.9 on mine until I experience any problems.
Just be watching v2.0!!!!!!
Sent from my U30GT 2 using Tapatalk 2Randy
Just to report..my M8 Pro is doing almost perfect with 1.9. Very pleased.
When 2.0 is available ..even better? Wow ..is all I can say.
I do have a simple question, if someone would answer.
When I get ready to load 2.0 ....I will do a CWM backup of what I have now. After I load 2.0, does a restore through CWM restore my apps and launcher I now have in 1.9 .....or does it change it all back, including the 1.9 ROM?
Thanks again.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by rrileypm View PostIf your tablet is acting up with this ROM...by all means...feel free to flash back to 1.7. If it is more stable for you.
hi thanks for your advice but if i go back to 1.7 i will loss multitasking function
v 2.0 when is going to be out? any idea?
Have you tried it ?
Reboot Issues
Hello Riley.
I tried to clear both cache and devil cache in CMW, it seems to work for the first time , but after the second reboot it seems there are two issues :
1. Every Second Or Third reboot the tablet needs a hard reset (reset with a paper clip) after it won't start (black screen).
2. When charging and turning the tablet off , it won't start while charging or not until hard reset (i.e. paper clip) is done.
Other then that the rom is really great.
Any Ideas , did anyone had this issue ?
Correct. Tested it and with multi windows on, it works like it should.
[QUOTHeerin83Tod 6]Hello Riley.
Any Ideas , did anyone had this issue ?[/QUOTE]
Same here, after unplugging after charging dark screen, no response. This happens since 1.8.
My workaround is to plug in the micro-usb cable and press the power-button.
But keep on doing other great Roms. Thank you Randy
There are currently 2002 users online. 0 members and 2002 guests.
