You can get the updated FW here - https://forum.freaktab.com/forum/tv-...-android-7-1-2
Firmware needed for T95Z plus 3gb 32gb android 7
Originally posted by mibmt View PostHi everyone, I have the T95Z Plus
3 GB + 32 GB
Wlan chip AP6255
Firmware 7.1.1
T95ZPLUS-3GB-v1072-JR9377 Firmware
I have the problem of the Google Play Store constantly the authentication is not stored and and with each new call the authentification again appears and he also saves the settings as no automatic updates. What can I do? Please umd help thanks!
[email protected]
Facebook https://www.facebook.com/profile.php?id=100009948972399
Lasslo Reilo
T95ZPLU-3GB-7.1.2 : https://mega.nz/#F!B4oGXbjL!CFwTkddudrMDa5SfKlN9Kg
Originally posted by gefattern View PostHi to all ,
here you can find FW too :
good luck / no guarantee / greetings / gefattern
Originally posted by manvel View Post
And which one is v. 1075 , android 7.1.2 for T95Z Plus??
you have to look for the right Model , in row two is the one for your Model ,
but i do not know the Versionnumber , you must look self and try , i only
gave a Hint to a FW for your Box , you can ask them with Mail .
No Guarantee / greetings / gefattern
Originally posted by Chito307 View PostI'm so sorry I mistyped. It is version 1015 not 1075. I cannot connect to any WiFi it says saved but will nor connect
that sounds not nice , did you ever tried other Router Settings , or reset the Router , changed the Android Wifi Settings ???
is the Link FW the right one ???
good luck / gefattern
It is Android hotspot on stock nougat. So there are no settings. It is very weird because I am able to connect to hotspot on marshmallow on a different phone I have that is the same model as the one on nougat. I have replicated every setting, apn, build.prop setting from marshmallow phone and it will refuse to connect to nougat hotspot. Wondering if anyone out there is encountering the same problem with the latest firmware 1015. I have two phones on nougat and it will not connect to either.
Originally posted by Chito307 View PostIt is Android hotspot on stock nougat. So there are no settings. It is very weird because I am able to connect to hotspot on marshmallow on a different phone I have that is the same model as the one on nougat. I have replicated every setting, apn, build.prop setting from marshmallow phone and it will refuse to connect to nougat hotspot. Wondering if anyone out there is encountering the same problem with the latest firmware 1015. I have two phones on nougat and it will not connect to either.
look here :
Could you provide link to this new 1075/7.1.2 firmware????
Hi ,
update: I have to change IGMP Snooping ->NO .... and WfFi disconect and freezing is history....
Some can try ti deactivate Quality of Service QoS in rooter seting.Last edited by lenkosmrk; 12-28-2017, 19:12.
Originally posted by Karce View Post
What found was that there's 2 Google Play's on the T95Z 7.1.1. One google play (which I believe is called Play Store) is a fake, which downgrades Google Play to version 6. When you re-run it, it updates to version 8.
here's what I did.- Install new launcher (I used TVLauncher) and make it the primary launcher by pressing the home button on the remote and then select "Always"
- Open RootExplorer and navigate to /system/apps/
- In that folder, you will find a directory called "SunvellWin8Launcher", go into that folder.
- in that folder, you will find the .apk for the original crappy launcher. rename it to add the extension .apk.bak instead of .apk (SunvellWin8Launcher.apk.bak)
- click the "+" sign at the bottom right to create a new (empty) file, name it using the original name ("Sunvellwin8launcher.apk")
- Go into Settings > Apps > Show System Apps and find "Play Store" (Not "Google Play Store") and disable it. If you're unsure if you selected the right one, you should see it as Version 1.0. If you see Version 8.xxxxxx you're on the wrong one, keep scrolling down the apps until you find "Play Store"
When you restart the box, your new launcher should auto-start, and you should be able to see the Google Play Store in the Apps and launch it normally.
Here are the caveats:- You will not be able to control the LED glow, it will stay the aqua/teal color.
- You will miss some settings (such as screen resolution) that are built into the swin8launcher that you won't find in the normal settings.
- You will not be able to control the screensaver time-out.
I'm currently waiting for a chinese company to send me another firmware which fixes the google play issues. If I find it is good, I'll upload a link to it here.
Thanks for excellent post, followed your instructions, used Nova Launcher, all worked perfectly for me :-)
I noticed your other thread with a ROM upgrade to 7.1.2, is it worth upgrading from Android 6.x.x to this new ROM?
Originally posted by Jeffers View Post
There are currently 2620 users online. 6 members and 2614 guests.
