Here is the thing.. Ive read so much. Now its confusing. What if you wanted to stay on a finless rom and flash just a new kernel. Ive read where you can. Ive read where it says not to. So question is on a cx919 with finless JB 4.2.. Can you flash kernel seperate? If so do you use the tool that flashed the the rom and check just the kernel?
Finally Found A ROM - Kernel Combo That Works For Me: CX-919
Some instructions.
Originally posted by peety View PostHere is the thing.. Ive read so much. Now its confusing. What if you wanted to stay on a finless rom and flash just a new kernel. Ive read where you can. Ive read where it says not to. So question is on a cx919 with finless JB 4.2.. Can you flash kernel seperate? If so do you use the tool that flashed the the rom and check just the kernel?
Originally posted by poul50 View Postflash this http://api.viglink.com/api/click?for...37545235071611 in recovery partiton and reboot to recover then you have option to backup and recover all your system and aps
Link not working. Getting the following message:
"Parameter 'out' is required."
smithmal
Just wanted to note that I've tested the following combo and it is working well:
Nexus ROM v2 (SDK2)
Finless 1.4 4.2.2 kernel
Benefits over OPs combo:
1. No rotation issues with different launchers (rotation fix unneeded).
Edit - sorry still having rotation issues with this ROM
The Nexus ROM is the only ROM that I've found seems to be compatible with Hulu Plus on the CX-919
Other benefits:
1. Runs native XBMC 12.2 with no issues streaming 720P videos
2. Official Google 4.2.2. port
3. BT and WiFi working well
Issues
1. Running in Phablet (not a big phablet fan)
2. Overscan issues (all sides cut off)
3. Rotation issues with certain apps (rotates -90 degrees into portrait)
Antut Benchmark Score: 15856
smithmalLast edited by smithmal; 12 August 2013, 19:58.
Hello,
i have a cx919 with original os 4.2.2 stock with the black nand problem.
the android mini pc is in use by a heavy gaming people.
so i only want the solution for the above problem.
becouse sometimes games need 15 minutes to be visible in nexus launcher.
at this time the stick is very very slow in system-menus etc.
question:
1. does i can flash only the kernel file over the original 4.2.2 rom
2. which opportunity i have to save alle save-games in angry birds etc, becouse titanium backup not working proberly, may the save-files in different folders as data/obb???
hope flashing kernel file also work with stock-roms...
There are currently 1587 users online. 0 members and 1587 guests.
