T95KPRO-2GB-v1015: https://mega.nz/#F!5lZSHbYB!gkWtSxJZTsiN0g24tRIyoQ
(ROM) Sunvell T95K PRO 7.1 2GB/3GB Firmware Update
Originally posted by mitchschaft View PostThanks for the tip. I have the files in my possession now!
Have you noticed anything else that's different? I wish they would release a changelog.
I havent really noticed much as only been installing a few apps and sorting out Kodi but what i can say is the box feels more responsive and faster and the Android now is 7.1.2
I didn't have any issue installing this latest update on both of my T95K Pro boxes. The only issue so far is I can't boot to the sd card using the toothpick method after it's installed. So I can't install TWRP (v3.0.2) like I could with the other versions. Not sure if I'm missing a step so I'll keep working on it.
I've been messing with it all night and TWRP 3.0.2 doesn't work with this firmware. This is what I have used on other versions and it gets stuck at the main boot screen (T95K Pro): https://forum.xda-developers.com/and...-plus-t3557812
I've tried the stock 3.0.2 and it will make it past the boot screen, but will hang with "error" and the android guy lying down. So I can only assume that file needs to be fixed somehow. It's probably something little, but I don't have the skills to edit the .img.
Originally posted by mitchschaft View PostI didn't have any issue installing this latest update on both of my T95K Pro boxes. The only issue so far is I can't boot to the sd card using the toothpick method after it's installed. So I can't install TWRP (v3.0.2) like I could with the other versions. Not sure if I'm missing a step so I'll keep working on it.
I needed to use the toothpick method even after updating. I also updated using the sd card method just for the heck of it and it worked no problem. I just can't boot to the sd card if the twrp recovery.img is on the card. This version doesn't like twrp for some reason.
Also, I noticed the LED button on the remote no longer functions. So you are stuck with the led being on.
This tool looks promising for objecting twrp into the build. But I can't get it to work. It hangs at 60% . I really need twrp.
Amlogic Flash Tool & Recovery Porter 6OkMMI3WQ9M Welcome to the Amlogic Flash Tool! TOOL IS NOW OBSOLETE, GO TO THIS THREAD FOR NEW PORTING TOOLS/OTHER AMLOGIC TOOLS
What I was ment to of said is once the new firmware is installed to the box the toothpick method is not needed if we have a future updates or a reflash maybe TWRP is not compatible with the new 7.1.2 update hopefully TWRP gets updated to support it but I could be wrong as IV never used or learnt how to use or install TWRP, I'll email sunvell and also notify them about the led button not working.
I meant the same thing. Even after installing this version, I still have to use the toothpick method. I have reflashed several times.
But I've read that others can't get twrp 3.0.2 to work with android 7.1.2. Somebody needs to edit twrp and I just don't know how. I think I'll post in the thread on xda where the original guy got twrp 3.0.2 to work with this box.
*EDIT*
Apparently the twrp file isn't patched to work with 7.1.2. I have a different file to try. I'll keep this thread updated and share the link if it works.Last edited by mitchschaft; 03-12-2018, 05:23.
There are currently 8884 users online. 3 members and 8881 guests.
