(ROM) Sunvell T95K PRO 7.1 2GB/3GB Firmware Update
Originally posted by matrix777 View PostWhen i restart the android box it comes back but not sure its a bug on the newest firmware link from eggyfresh ...will double check
When you hide the navigation bar you should be able to bring it back!
This is how it works because without bar no Navigation...
Originally posted by eggyfresh View PostHi everyone i have some great news for all you Sunvell T95K Pro owners like many of us i bought this box and it had the dark picture problem and WiFi issues and i searched everywhere and could not find a way for my box to work perfect i did try a few different firmware's some features just didn't work i also tried looking for the 7.1 firmware and again no luck finding it, i also tried to search sunvell's official website using google again couldn't find anything so by chance i typed in Sunvell.com and i was able to contact Sunvell directly via email and after 2 days of waiting i was given download links from Sunvell's software engineer called Willie Xu to download the new Sunvell T95K PRO 7.1 firmware and all i can say is all my problems have been fixed and my box is working perfect.
T95KPRO-7.1-912-2GB-v1072
Firmware link:
T95KPRO-7.1-912-3GB-v1073
Firmware link:
https://mega.nz/#F!I952CYIb!xQ-VLMhVierXVhfbShxFGQ
Is there any newer version that fixed problems?
@noahv......eggyfresh posted two previous firmware links from Sunveil is this one u posted a 3rd updated firmware for android 7.1 if so does the navigation/system bar work for u once u click for it to disappear is it easy to bring back...and what is Sunveil email i need a firmware for their T95V pro 2gb/16gb...preferably 6.0 dont think a 7.1 is out as yet
I've installed the newer firmware posted by Eggyfresh. Everything seems to work fine in my T95k pro. The only bug i've faced is that everytime i reboot / turn on/ resume from standby my box, the System language revert to Chinese and i have to change it to my language (Italian). Has anyone found this bug and how to fix it?
Inviato dal mio MI 5s Plus utilizzando Tapatalk
Hello!
Does anyone use Teamviewer Host with that 7.x Firmwares?
I have the Problem, that Apps suddenly crash / end if i use Teamviever.
With a Custom or Stock 6.x Firmware for the T95K pro there is no Problem using Teamviewer...
Or is there something i have to consider when i use TV in A 7.x ?
Originally posted by davzarI've installed the newer firmware posted by Eggyfresh. Everything seems to work fine in my T95k pro. The only bug i've faced is that everytime i reboot / turn on/ resume from standby my box, the System language revert to Chinese and i have to change it to my language (Italian). Has anyone found this bug and how to fix it?
However the fix is:
Go to settings > HDMI CEC > CEC Switch: On > Auto change language: Off
There are currently 11398 users online. 5 members and 11393 guests.
