H96pro plus keeps crashing
    Originally posted by Agoraroja View Post
    I´m in the same situation. H96 PRO+ PLUS 3GB 16GB DDR4 from TOMTOP. The tv box crash, freeze, reboot and do not work with any of the lastest official firmware. I do not what to do. It seems there are a lot of defective tv box with the inestable rom.
    TOMTOP do not give me a solution and I think the stole my money.
    Any idea???? Any Solution?
    I read Superceleron solutions but I am confused about all the costume roms.
    Thank in advance
    According to this post, this Superceleron firmware works on your box.
    You just need to copy your original remote.conf file across to get the remote to work.
    http://freaktab.com/forum/tv-player-support/beelink-aa/beelink-android-tv-box/gt1-ultimate/firmware-roms-tools-ch/637148-rom-beelink-gt1-ultimate-scv2-atv-android-tv-ddr4?p=662318#post662318
      Originally posted by gefattern
      Hi badster ,
      about Power maybe 2500mah or 3000mah / 5V/2500 or 5V/3000 ,
      but first maybe this ,
      do you have the DDR4 Version , maybe this Rom works :
      http://freaktab.com/forum/tv-player-...ndroid-tv-ddr4
      I think the Beelink GT1 Rom works too , but please , first ask in the specific Thread .
      Maybe you can find some helping Info or Rom here :
      http://freaktab.com/forum/tv-player-...h96-pro/page10
      read all before you do anything , good luck
      greetings
      gefattern
      Thanks a lot
      Finally I can use the box without freezing and apps stop responding
      But I was wondering, this one is ATV and the play store has almost nothing, not even gmail, Firefox, just a few apps.
      Is there any way to get the "real" play store on this ATV?
      If not can you or anyone reccomend another firmware that works for DDR4 (H96 pro plus 3/32)
      Ive been looking through the forum, but find it hard to find non-ATV DDR4 firmware
      Cheers guys
      Sent from my SM-G930F using Tapatalk
        Hi badster ,
        i have to investigate give me some time , please try to wipe cache ,
        the non ATV Apps can be seen over AppDrawer or use Apk.pure. like
        Store .
        greetings
        gefattern
          Hi badster ,
          Store .
          greetings
          gefattern
            Hi badster ,
            does it work now , why thanks ???
            nice Day
            gefattern
              Sorry no, Im at work so I cant check now, just saying thanks for the help
              You mean clear cache on play store?
                Hi badster ,
                yes u can use this App from SpecSoft to clean cache and Dalivk , then reboot and wait till
                Box is ready .
                This cleans and rewrites the data new in to the caches , or something like that , i am no Dev. .
                talk you later
                gefattern
                  Hi, whats the name of the app? App from specsoft
                    Hi badster ,
                    clear cache (grey trash Can) Icon .
                    Play Store alternative :
                    https://www.google.de/search?q=apk+p...obile&ie=UTF-8
                    with first Link you can download the App .
                    gefattern
                      Hi badster ,
                      did it solve your Problem ???
                      greetings
                      gefattern
                        Hi badster ,
                        greetings
                        gefattern
                        I tried it but it didnt fix it no
                        But thank you
                        Maybe Im going to hunt for a non ATV rom for DDR4 s912
                          Hi badster ,
                          here are some other Roms for your Box ,i think you can try the Beelink GT1 CustomRom ,
                          but please ask there first :
                          http://freaktab.com/forum/tv-player-...wise-s92-scv10
                          not sure if the same WifiChip .
                          good luck
                          gefattern
                          Last edited by gefattern; 19 August 2017, 12:50. Reason: always this stupid Â* pops up after save so i have to edit
                            To badster ,
                            for a better Overview :
                            http://freaktab.com/forum/tv-player-...-roms-tools-by
                            to search , maybe Coolio can help to add a AppDrawer so you can use non ATV Apps too without Problems , same with
                            PStore , good Dev. , was there a AppDrawer in the other Rom ??? , what about the Superceleron Rom already tried ??? ,
                            good luck
                            gefattern
                              I tried this rom now
                              Its for DDR4 and so far so good
                              Working good on my H96 pro plus 3/32 ddr4 finally
                              Thanks a lot
                                Hi badster ,
                                that is the best message u could make , remember always Backup before trying another Rom .
                                good luck , nice Day
                                gefattern
