H96pro plus keeps crashing
    Hi badster ,
    here a alternativ Rom for your Box , look here , Scooter write it works for your Box :
    http://freaktab.com/forum/tv-player-...20170720/page3
    dont flash it if you happy , but you know it now , for Future , it is 7.1 .
    have fun with your hopefully well running Box now , greetings
    gefattern
      My original remote doesn't work,
      Can anyone upload or email me remote.conf for H96 pro plus?
      Sent from my SM-G930F using Tapatalk
        You may be able to get the right information from this post
        http://freaktab.com/forum/tv-player-support/general-tv-player-dicussions/633528-we-need-your-remotes?p=640547#post640547
          Originally posted by bluesmanuk
          Thank you
            In 6 you can change in droid 7 not possible not a easy fix.
              Ok thanks
              I have GT1 Ultimate ( http://freaktab.com/forum/tv-player-...l-android-ddr4 )
              I have the remote.conf now, but I should put the file in which folder? /etc/remote.conf <- ?
              I can't find the /etc folder omg
              Do I need to root to navigate to /etc folder ?
                Hi badster ,
                yes , yes , yes
                good luck
                gefattern
                  Ok
                  I wasnt root on my box so I couldnt go to /system/etc, but i turned on root and edited the file, now it works Thanks
                  The rom is working good so far, no crashing, but when I switch hdmi source then the box goes to sleep?
                  Any ideas how to fix it so it doesn't go to sleep?
                    Do you have HDMI CEC turned on in both the TV and box?
                      It was off on the box, but it was on on the tv, I didnt know about it haha
                      Now it doesn't sleep, thank you
                        2 problems fixed.
                        Now that is a result
                          Yes thanks all you guys, great help here
                            Hi badster, would you be able to put all the steps that worked for you in fixing the problem in one post? Thanks
                              Hi Aaron ,
                              what is exactly your Problem ???
                              please answer
                              gefattern
                                Just got a new H96 pro+, and it is pretty much unusable e.g. https://youtu.be/bbUQkucJEXs
                                Not sure what memory I have, it says DDR3 on the box, but may not be inside. Am asking the supplier for assistance, but thought I look around myself as well, and badsters solution might be Ok for me?
