"New firmware" H96 PRO+ Amlogic S912 TV BOX KODI 4K 3G/32G DDR4 android 7.1.1 and twrp recovery.
    hi guys
    Will this work on my OTT TV x98 PRO?
    X98 pro
    CPU Amlogic S912 Octa-Core ARM Cortex-A53 64-bit @2GHz
    GPU Mali-T820MP3 GPU @ 750MHz
    Memory DDR3 3GB
    Flash eMMC 16GB
    WiFi 2.4G/5.8G/ 802.11 b/g/n/ac
    Bluetooth BT4.0
    Moudle Aluminium: Black Color
    I/O 1 x HD 4K x 2K UHD Output, HD 2.0a
    1 x AV OUT Composite video and audio output
    2 x USB 1 x USB Host Port, 1 x USB Device
    1 x OPTICAL Digital Audio output
    1 x RJ45 Ethernet Gigabit Interface
    1*TF CARD Support 4GB~64GB
    Or is it better to use some other rom?
      I flashed the twrp image via the official twrp app, and I can't enter recovery anymore by keeping the reset button pressed. It just boots the standard system instead of the twrp recovery. Is there some sort of additional trick I have to perform?
        I have the 2017-06-19 firmware running, which perhaps isn't compatible with the twrp in the original post. I found a twrp there, which worked for me:
