Mini M8S PRO Android7.1 OS
Hello,
It dont work on Mini M8S PRO 2G/32G (https://www.gearbest.com/tv-box-mini-pc/pp_624887.html)!!
I have this error on usb burning tool
[HUB1-2][Err]--failed:[18:13:41 929][HUB1-2][Err]--Check command return failed
[HUB1-2][Err]--[0x30201004]UBOOT/Disk initialize/Send command/Error result
My box is now bricked! Any idea to unbrick it?
PLEAAAASE HELP
PLEAAAASE HELP
Originally posted by AZW View Post
try to flash it.
Any Idea? Firmware not compatible ? Other think to do? Hardware issue?!
Originally posted by AZW View Post1, please send us a picture of the problem you have.
2, please share SN.
and SN
If this firmware is not compatible can you share old one to unbrick my box?
Last lines on logs:
[19:13:09 947][HUB3-2][Inf]-------------Download meson1.dtb-----------
[19:13:09 947][HUB3-2][Inf]--0-7-0-16
[19:13:09 947][HUB3-2][Inf]-- download mem dtb normal 137216
[19:13:09 947][HUB3-2][Inf]--Send download command success
[19:13:09 963][HUB3-2][Inf]--Read command status success
[19:13:09 978][HUB3-2][Inf]--Transfer complete
[19:13:09 978][HUB3-2][Inf]--Send download get_status command succeed
[19:13:09 994][HUB3-2][Inf]--get_status success
[19:13:10 510][HUB3-2][Inf]-------------ERASE FLASH-----------
[19:13:10 510][HUB3-2][Inf]--disk_initial 1
[19:13:10 510][HUB3-2][Inf]--Send command success
[19:13:11 666][HUB3-2][Err]--failed:[19:13:11 666][HUB3-2][Err]--Check command return failed
[19:13:11 681][HUB3-2][Err]--[0x30201004]UBOOT/Disk initialize/Send command/Error result
[19:13:11 681][HUB3-2][Inf]--Close device handle 0x0000059c
Regards
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Hi All
I have also this one of the Mini M8S Pro box (2/16Gb) and was some wrong opinion with this box software
I read some article from web, and i am find much firmware what function on this box.
Probed and installed some of them, here is my list what were good
I use the USB Burning Tool to load rom.
I think a lots of firmware work this box, only must focus the s912 (q201 board) and q9377 chipsets.
When you want install a wrong image, the Usb Burning tool wont load this, so you couldn't make brick your device.
stock:
GT1
http://freaktab.com/forum/tv-player-...-roms-tools-cg
also android 6.0 and android 7.1 is function with remote, and has many installed apks and lots of tweak
Ugoos
http://freaktab.com/forum/tv-player-...-for-ugoos-am3
this is the newest rom
Tronsmart
http://4pda.ru/forum/lofiversion/ind...82359-240.html
now i use Mod Ugoos AM3 1.1.4 Android 6.0 firmware, because this has own youtube app where you could use infra remote to controll, and all youtube app playing the 4K videos.and has Nav Bar
Nexus
https://onedrive.live.com/?authkey=%...C979F57D71A88A
Gt1 and nexus roms
Hope that i could help!
Thx
waiting the feedbacks....
Hello zsolt64555 , hello all
thanks for response
I try with all firmware listed
for Tronsmart the lincense.zip link is broken so i have a license issue on USB BURNING TOOL
For all others firmwares i always have a same issue:
[14:48:48 941][HUB2-2][Inf]-------------ERASE FLASH-----------
[14:48:48 941][HUB2-2][Inf]--disk_initial 1
[14:48:48 941][HUB2-2][Inf]--Send command success
[14:48:50 051][HUB2-2][Err]--failed:[14:48:50 052][HUB2-2][Err]--Check command return failed
[14:48:50 135][HUB2-2][Err]--[0x30201004]UBOOT/Disk initialize/Send command/Error result
[14:48:50 135][HUB2-2][Inf]--Close device handle 0x000003d8
i have have after flashing recovery so may be a NAND is broken!!!? can i force reset NAND?
also, i have a Mini M8S Pro box but 2G/32G model. It change anything?
Wait for response
There are currently 1530 users online. 0 members and 1530 guests.
