Mini M8S PRO Android7.1 OS
    Originally posted by AZW View Post
    yes, would be soon.
    I have no idea about OTA, if yes, you will get notification, right? otherwise, we will update link here.
    Is there a firmware update for the Mini M8S Pro 3gb/32gb yet?
      Not yet, we may release new firmware at the beginning of Nov.
        Does anyone have Android 6.0.1 firmware for this device. Specifically, I'm looking for "Mini M8S Pro TV Box - 2G + 16G) Android 6.0.1.img"? Many thanks in advance!!
          Thanks for the update. Hope to see it soon.
            AZW - thank you for posting this image.
            Amglogic CUSTOMIZATION TOOL 2.0.8 BUG
            Has anyone else noticed this? If you download this image, unpack it using the Amlogic Customization Tool 2.0.8 or 2.0.10 and then repack it (without modifying anything), the resulting image is BROKEN?
            Steps:
            1) New Mini M8S Pro (2G x 16G)
            2) Download this IMG for USB flashing: https://beelink-my.sharepoint.com/pe...PEmGaH05_zVFzs
            3) Open in Amlogic Customization Tool 2.0.10
            4) Unpack Image
            5) Don't touch ANYTHING
            6) Repack Image and name it something other than the original name
            7) Open Amlogic USB Burning Tool 2.0.8
            8) Load image file you just created
            9) Flash it
            10) When the flashing process is finished, the "4K Ultra HD" Bootup Logo will appear and then do NOTHING. The boot process freezes before reaching the bootanimation.zip sequence.
            In summary, the resulting image has gotten corrupted somehow and the boot-up process is broken at the Ramdisk or K ernel partition (my guess).
            Does anyone have a suggestion on how to fix this? AZW?
              please try steps as most people did. let's see if it's still have problems...
                I've tried this process several times. The original image downloaded from here: https://beelink-my.sharepoint.com/pe...PEmGaH05_zVFzs works just fine for me every time I flash it. But the moment you unpack and repack the image using Amlogic's Customization Tool, the resulting image is corrupted and will NOT boot properly (even if you leave the image untouched after unpacking and then repack).
                Are you able to replicate this problem following my steps above?
                  here comes new firmware: https://beelink-my.sharepoint.com/pe...e14406579f73b8
                  We did:
                  1, add navigator and status bar,
                  2, add APP store.
                    We did:
                    2, add APP store.
                    Hello,
                    I tried to flash this last one on my mini m8s pro 2G/32G without success
                    always same error:
                    [23:55:35 481][HUB2-2][Inf]-------------ERASE FLASH-----------
                    [23:55:35 481][HUB2-2][Inf]--disk_initial 1
                    [23:55:35 481][HUB2-2][Inf]--Send command success
                    [23:55:36 645][HUB2-2][Err]--failed:[23:55:36 645][HUB2-2][Err]--Check command return failed
                    [23:55:36 829][HUB2-2][Err]--[0x30201004]UBOOT/Disk initialize/Send command/Error result
                    [23:55:36 829][HUB2-2][Inf]--Close device handle 0x000003b8
                    My nand is KLMBG8FE4B-B001
                    Please help! its still bricked
                    Any Idea??!!
                      Originally posted by redsparrow View Post
                      Hello,
                      always same error:
                      Any Idea??!!
                      how many % have you flashed?
                        Hello,
                        always same error:
                        Any Idea??!!
                        please try:
                        1, when you try to flash, after connect USB cable, make the device power on ASAP.
                        2, Press "reset" button if you can find it, then connect USB cable to flash.
                          please try:
                          I already try presse reset button but i have a same error and always at 7%
                          À sizing Can change anything? I have 2g/32g model
                            We did:
                            2, add APP store.
                            How do I flash this on a Mac? I’m new to flashing/updating firmware on these android boxes.
                              right now, only flash tools for Windows os...
                                One quection about mini m8s pro-c with 100mb lan, it is the same? The wifi chip and memory it the same with mini m8s pro?
