SCISHION V88 Mars II Smart RK3229 2/8GB WiFi, Fast Lan
Hello
Thanks for the tutorial.
I flashed v88 mars II this way but before no devices found in the end I disconnected the box from usb otg and power adapter, now there is nothing over hdmi on screen and I tried multiple times again to flash it but I dont get connection on rkdevtool.
What shuould I do now?
I use usb male to male, driver installed properly and tried both devtool and batch tool but no connection. I did flash it once and probably before successful reset device message I unplugged it. Also I am not wuite sure whick usb port of the two is otg? The one next to reset hole or the one after micro sd slot?
this is the way I do it, plug usbcable to box and press reset hole and then plug the adapter, is that proper way?
thanksLast edited by kidjej; 16 August 2018, 17:16.
Originally posted by kidjej View PostI use usb male to male, driver installed properly and tried both devtool and batch tool but no connection. I did flash it once and probably before successful reset device message I unplugged it. Also I am not wuite sure whick usb port of the two is otg? The one next to reset hole or the one after micro sd slot?
thanks
Mate I tried that all (bought another usb to usb cable, tried different ports. Reinstalling druvers) but unofrtunatelly nothing happens, connection could not be established, but when I connect power adapter into the box you can hear some buzzing, so its not dead completely, no lights though.
cheers
Originally posted by tedyuri View PostV88 mars ii frimware plz send with me
Click image for larger version Name: v88.png Views: 1 Size: 84.7 KB ID: 657651 Specification Brand: scishion Model: V88 Mars II Type: TV Box System:
There are currently 2878 users online. 0 members and 2878 guests.
