Regards
[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Hello, I flashed the 'TVStock Variant: BURN PACKAGE (980MB IMG file)' using USB Burning Tool and Youtube TV won't play any content but does play advertisements fine. I receive a 'Playback Error' when trying to watch any media from the Youtube TV app. I am able to view media on the Youtube app.
Any suggestions on how to be able to use YouTube TV on my Mecool M8S Pro S912? Thank you and appreciate the development and support.
Thanks for reply MagenDanz. I too have a support ticket opened with YouTube Tv, ill keep you updated.
Also to add to my confusion, Hulu is giving a similar error now. Stating ' Playback Failure'. Code (-978). Hulu response to my inquiry was this device is unsupported.
Seems strange, but pointing to a bigger issue at hand. Hope this isn't the end of my Mecool M8S! Thanks again.
Great rom, just flashed it the other day. I have only one problem, for example, when I turn off my tv in the evening and woke up in morning i turn on tv but box is in sleep mode. There isn't picture but blue led on box is on, non of buttons on remote don't wake it up, just turn off button works and it just turn of the box, so i need to turn it back on. I have set in options to never go to sleep, and in developer options is set stay on while plugged. Is this known bug or it's just me? Thx
Guest, thx for quick response. I have a pi fan installed since i bought box, my temp does not go over 31 Celsius, and when this sleep occurs the box was left on home screen, so i don't think is temp related. It was problem on oem rom and now on this nexus rom.
PS
Why when I go under more setting there isn't option never go to sleep like under normal display settings, you can just check max 30 min?
Maybe its because the android version, maybe I need a new box. I've been using your port for months, so thanks you.
Also I want to report that the Disney+ app works on the Mi Box Android 9 firmware ported for S912 (rom on xda developers forum). It worked out of the box, no Aptoide. Still prefer nexus port.
Also it's glitchy on slim box tv, using the Aptoide version ( another android 9 port). Pie port has display problems and random glitches, tv box port same issues and no sound.
There are currently 1875 users online. 1 members and 1874 guests.
