[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Magendanz, The USB burning tool did not work, somehow my PC and the device would not get connected. Found instructions on booting from an SD card. Thankfully that worked I am now on the Aug 2018 firmware version. Thanks for your help.
Do you have some insight on why I had the roll back of my play services and other apps and the whole look and feel on the Nexus build. Was it just me ?
Hi Magedanz , can you help me with problems of app netflix for android tv, error UI-800-3 ?
Is there a solution?
thank you for all!
#993.1Guest commented26 December 2018, 22:09Editing a commentNot really. It used to be that Widevine L1 was enough for Netflix, but they've recently rolled out new whitelist system that only supports certified devices. There's lot of discussion on this in the forums, but I haven't heard of a reliable way to circumvent it yet.
Dear all', I Need help. I bricket my m8s pro, I Tried to unbrick in many way,last with burning tool tool and magedanz & stock Image,but when I reboot the m8s pro device I glsee the android with Red "X" . I don' t know what is the issue Is and what to do....thanks ti all
Sorry Magendanz, do you mean the Image in the First Page of this post? I Just Tried that with Amlogic burning tool, with success,but when I reboot the m8s pro I have android with Red X again... Or do you have another good Image? Thanks again
good morning guys! where can I find youtube for android tv? I can not install updates for my youtube on the play store. The application stops responding. It makes me only install normal youtube for smartphones!
What is the procedure? I do not know how I should do it ... I just have to install youtube for android tv.
There are currently 1582 users online. 0 members and 1582 guests.
