Yes, it worked.
[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
[Solved] Amlogic TV Box Flash Error - Uboot/Get result/DiskInitial error - 7%
Here the video, I posted on YouTube, I had to put a filter because I shot in the dark and the image turned red and there is no audio:
The video is just a confirmation that worked. So if you are going through something similar do not give up on your device. For more details on the error click here.
1° I cut my 1 meter cable and sewed it with solder, but it did not work initially on the first notebook.
2° I cleaned on the motherboard of the box, with "clean contacts". Well, I do not know if that made any difference, I could only test days later.
3° Maybe that was the cat's leap, I made the flash on a newer laptop, with Windows 7 and with all Windows updates installed.
Extra: At some point I tried the Boot in a Linux distribution (Armbian) by the memory card, but I could not initialize the distro, restart in the Nexus logo.
So I went on the PC, and took the first picture I read the Stock's name (thinking it's the OEM firmware), when the flash came out I realized I had chosen the Nexus StockTV image. Iol
Special thanks to: lyubodelev and supermalLast edited by Novato; 24 August 2018, 17:04.
And now what? MIBOX3?
Look what a nice clock widget I found!
https://www.dropbox.com/s/j4gt2rkilw...93015.png?dl=1
That's better! Open with Dropbox!Last edited by lyubodelev; 24 August 2018, 18:00.
Originally posted by Novato View PostDude, it's cool, I just do not know if it competes with Mibox 3. The MiBox interface is designed for use with remote control. But changing its interface is pretty cool. I bet you spent a long time setting it up, huh? haha
Originally posted by Novato View PostIt sounds interesting, it's always nice to have other firmware options. Usually minix handsets have a built-in hearing aid. It would be interesting to couple a USB Wi-Fi adapter to our TV Box natively. Any way any network card related problem would be easily solved.
wifi somehow is working, I don't know how, as on Minix it is AP6255...
Originally posted by lyubodelev View Post
Look nice!
Yes, I have seen some reviews, they are more expensive than the ones we use. the Wi-Fi is a highlight. It's only a shame that Minix does not offer native support for Android TV. Although I have already solved this with MiBox, which should arrive soon. It already has the Android TV Oreo.
Originally posted by Novato View PostFor example in the Armbian distribution, if not mistake it is possible to install any adapter and the device will recognize.
You may try it, without working lan! Do you want?
Here is what you want, but for Ugoos!
http://4pda.ru/forum/index.php?showt...ost&p=73599200
Originally posted by Novato View Post[Solved] Amlogic TV Box Flash Error - Uboot/Get result/DiskInitial error - 7%
Originally posted by supermal View Post
Glad you did not give up hope and succeeded in recovering your box!now you know what to do.all part of the fun.lol
Unfortunately it does not run 100%, of course my memory card is not the best, but it is a good system for anyone who wants to lose time with linux, lol. It was good I remembran how to run a sudo apt-get update && sudo apt-get upgrade.
In short, I already left the should aside and I'm starting to improve the Android TV OS again and again. I'm just in doubt about what I'm going to do with it when my MiBox arrives. But I do not think I'm going to sell. I'll probably replace the cooler with a new one and use it for games.
The author says to wait, and we wait!
There are currently 1384 users online. 0 members and 1384 guests.
