[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by Novato View PostIt's like the call to the wi-fi tried to start a process that is not responding. Then he will try another option. But it's just a guess. The first time I start the wi-fi it shuts off, if I wait a while and try again it will start normally.
Originally posted by lyubodelev View PostMamma mia!!!
Originally posted by supermal View Post
http://www.bee-link.com/forum.php/fo...&extra=&page=3 here is a link to someone with same problem.your box can be recovered but just need to get conditions right.the laptop you had might not have had the right drivers?
Originally posted by lyubodelev View PostTry this!
The device connected to the wi-fi, the problem is that when I turn on the device it is not able to start wi-fi, I do not know how to talk the way the developers would say, but if I click on off by itself. But when it finally goes live, it connects instantly with the wi-fi network and without keeping it until I reboot the device.
Originally posted by Novato View PostThe error persists, always generating at 7% ... I held how you directed me
http://4pda.ru/forum/index.php?showt...ost&p=72601887
When USB BT showed an error on 7% this guide pull off the USB cable by mistake. He was threatened of what he has done and quickly pulled in the cable back and, o, miracle - the process came to 100%!
From this point, he regularly uses this method!
Originally posted by lyubodelev View PostFound an interesting solution of the problem on 4pda:
Originally posted by Novato View PostLet me see if I understood, he removed the USB cable quickly and then quickly put it back? Or type it removes the cable does not put more? Because there would be no logic. lol
Just at one time namuchalsya with firmware. 7% gave an error. What I just did not try .. Got thorough. And then accidentally after the error was displayed, pulled out the USB cable from the console, got scared and put it back (on the screen 7%) .. The computer picked up the console, and the program as if nothing had happened to continue to sew .. Miracle, but the firmware has become. Till now I use ..
Originally posted by lyubodelev View PostI personally do the same thing, I do not press the reset button and USB BT gives me the same error, but on 2%. Then I pulled out and then back pulled in the USB cable to the box. The process continues to 100%!
People call this laziness...
There are currently 2013 users online. 2 members and 2011 guests.
