[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
I've never been able to do it with the USB Cable because on the other Notebook I used, I was not recinreconh the Box in the Burn Tool, and as I am currently without a PC I always do the firmware change through the MicroSD. But I borrowed a laptop and got it done, but this time the error must be for another reason.
The error persists, always generating at 7% ... I held how you directed me
Can you use the new charging unit with the box now?
Everything is in the experience... I don't even press the reset button while brushing...
Originally posted by supermal View Post
i normally get an error on mine when using burning tool.when the error occurs i unplug usb end connected to the box and plug it back in again.the burning process will then restart and hopefully complete without any more errors.ideally the usb to usb should be as short as possible.if laptop has more than one usb port you can try using a different one.also you can try with the power addapter connected to box at the same time.i have one box that this is needed for usb burning tool to work.trial and error until you get results im afraid.it has to be the right type of male to male cable or this could cause failure.but if you have used it before with success it should be suitable.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by lyubodelev View PostTake another firmware... but this is not good...
Thanks, I did as you directed, I tried on all our other USB ports. My cable is not the least, but I think that's not the problem, I used to flash it with an MXQ 4K. I do not know what else to do. My device is so cool, it's annoying to think that it will turn drawer bottom stock.
What would a new charging unit be? Is there a USB data cable other than the one I'm using for example from a cell phone or a different power supply?
the usb cable carries 5v from the laptop to the box so you dont normally need to connect the power supply.the power supply is the one you connect to the mains to power up your box for normal use.
There are currently 2311 users online. 0 members and 2311 guests.
