[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Hi, I got it do a "patch" on SDCard Burn, replace the firmware.img that was on the memory card (AM3 OEM) by the firmware.img I wanted to do flash (AM3 ATV), I changed the name to stay am3_2.0.6.img I started flash and It worked. I do not recommend doing so, but it was a solution for me since I do not have a PC at the moment.
Originally posted by supermal View Post
Was going to do twrp backup of am3 atv mod and upload it tomorrow.glad you got sorted.let me know what you think of the firmware.☺️
Thanks, but it's no longer necessary. I used the memory card with the SD Card Burn Maker method, in this process the Software extracts a copy of the Uboot of the firmware and with some information causes the update to be effective through the memory card. What I did was the second one, based on the AM3 2.0.6 firmware uboot I only changed the OEM firmware present on the memory card by the ATV firmware. It worked fine, but that's not true for other firmware, then I tried the same procedure with the Beelink GT1 ATV firmware and it was aborted. Luckily I had copy the AM3 ATV firmware and went back to what it was before. The next day I went to a family member's house and did the Burn procedure in SD using the PC. Currently my M8S Pro is equipped with the Beelink GT firmware that is not based on VideoStrong, as is the case here in the Topic. I prefer Shiningworth All-in-One based Firmware.
Originally posted by shr913 View PostHello what is the difference between TV Stock Rom 500mb version and the 800mb version. On the nano and stock page...I installed the 500mb version on my m8s pro and it works Great...just wondering if there is a difference...Thank you!Last edited by lyubodelev; 13 June 2018, 03:11.
There are currently 3127 users online. 0 members and 3127 guests.
