[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by Dmitry_N View Post
I can confirm that both Wifi and LAN get disconnected after a long sleep
I see big problem that I have to reconnect my box every time when it wakes from sleep mode up, especially when my IPTV app is there and the main purpose of properly working sleep mode is to wake the device faster up, so you don't need to wait a reasonable bunch of time until it boots up from scratch.
Originally posted by mirbg View PostI see big problem that I have to reconnect my box every time when it wakes from sleep mode up, especially when my IPTV app is there and the main purpose of properly working sleep mode is to wake the device faster up, so you don't need to wait a reasonable bunch of time until it boots up from scratch.
Oi mirbg, Dmitry_N e freeuser, I am currently using a new ATV firmware, based on Shiningworth All In One, and it is quite stable, it does not disconnect when it is inactive or when it goes to sleep. It was originally created for Beelink GT1, but currently it supports several devices, including M8S Pro, but unfortunately it does not have support for Netflix HD, but in my case it makes no difference, since my device does not come with keys for DRM L1. The firmware translation into Portuguese (my native language) is perfect, I believe that for those who use a language other than English it will have some advantages when opening the ATV settings. Well, that's all, you can download the firmware here, if bluetooth audio stutters like you're using a PSP emulator, you can use the audio patch for M8S Pro done by me thanks to Magendanz here, and if you have control of Air Mouse MX3 or similar you can use this other patch here.
Actually, the lack of L1 in Netflix and a weight, I had 3 devices, 2 Mecool M8S Pro without L1 and M8S Pro + with L1, I got to test and saw the change as it gives an Upgrade in the image. But the box with L1 did not have Bluetooth, in addition to the processor weaker, unfortunately the option was to sell. I looked in another post that Magendaz had to retire by job and only return there towards the end of the year. So unfortunately during this period will not have many updates, another thing not very exciting and that already came out Android 8.0 for some devices Rockchip, however for Amlogic was released code for Sets S905X and S805X but for S912 which is a more powerful SoC Amlogic has not released anything, and developers are looking pretty much for Android 8, so the news on moment is not very encouraging with regard to updates.
Hi! Ihave problem with mecool m8s pro 3/32. M8S not working and i not can reestablish. With UBT download only 7% and after error. Download farmware from sd card after cd card maker not working. I tried diferent computers and diferent UBT but m8s pro not can boot. Computer is can see m8s usb port.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
You can try with another card, preferably new, it can be a 4GB. I fortunately never had major problems with the programmed SD Card Boot Maker. Once if I'm not mistaken it worked something of the type but consehic review the system. I always do by SD card always using the PC to format every new firmware.
Originally posted by awantyrist1 View PostNot can load from cd card after card maker https://m.youtube.com/watch?v=UzVDyy8jEBc
Originally posted by Novato View PostOi mirbg, Dmitry_N e freeuser, I am currently using a new ATV firmware, based on Shiningworth All In One, and it is quite stable, it does not disconnect when it is inactive or when it goes to sleep. It was originally created for Beelink GT1, but currently it supports several devices, including M8S Pro, but unfortunately it does not have support for Netflix HD, but in my case it makes no difference, since my device does not come with keys for DRM L1. The firmware translation into Portuguese (my native language) is perfect, I believe that for those who use a language other than English it will have some advantages when opening the ATV settings. Well, that's all, you can download the firmware here, if bluetooth audio stutters like you're using a PSP emulator, you can use the audio patch for M8S Pro done by me thanks to Magendanz here, and if you have control of Air Mouse MX3 or similar you can use this other patch here.
Which file in this is should download and install?
[QUOTE=ashoktvm;n721433]
So we can install the firmware on this page without any problem?
[/QUOTE
Well, this firmware and basically the firmware of the Vorke Z6 with some modifications, ellele works without problems in our device. Use the last image, version 10.7, the developer is always giving support and sometimes launches some patches. Check out my links for more customizations and fixes.
There are currently 1292 users online. 1 members and 1291 guests.
