[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by Mss81 View PostTry if you can push a button inside the AV port. I hear nowadays sometimes THE reset button is hidden inside of the AV port for some reason.
Originally posted by a_stefane View PostHi, I recently purchase a new tvbox Mecool M8SPro ... it doesn't have a reset button ...
Shortcutting the shown two points will act as a reset button. Or shortcutting the points, where the reset button should be.
I believe this is the correct thread you want to be on.....
Now, the nexus ROM seem to be similar to factory stock ROM and google play store app is also limited ... any chance to have full google play store? ... I wonder how I will change now the ROM without update app.
L.E. thanks @lyubodelev
my M8S Pro:
I agree ... I successfully installed the nexus android TV using zip file (OTA update 531Mb zip file) on USB stick and update app of the stock factory ROM ...
Now you should brush you box with the USB Burning Tool - just to try the shortcutting of the points, if available (just till the burning process passes 7% and then release the shortcutting!) with the full image file. But my advise is to use the Nano package and may be playmarket will be full (I haven't tried this). If this doesn't work, we shall make another thing , but first try this.
Originally posted by a_stefane View PostI simply don't understand why there are two threads with ROMs for this box ...
http://freaktab.com/forum/tv-player-...ms-android-7-1
http://freaktab.com/forum/tv-player-...android-tv-7-1Last edited by lyubodelev; 13 May 2018, 16:33.
The first link uses the Leanback Launcher.Last edited by lyubodelev; 13 May 2018, 19:56.
Originally posted by lyubodelev View Post
This has happened to you, because the installed firmware on your box has been v0619.
My "Reset button" is now made up by two soldered wires (see red lines) on the place where it was supposed to be.
Thanks, installed finally M8S_PRO-V0928_Stock-20180310 with USB_Burning_Tool_v2.0.8_x86, now play-store is full.
Excellent!
Originally posted by a_stefane View Postcan we have bottom bar avalable without entering setup every time after minimize it?
Open Terminal and enter there the fallowing:
su
settings put global policy_control immersive.full=*
You don't need to add this in autostart, because these settings are automatically saved.
The bars should begin to autohide, so you will not have to close the navigation bar.Last edited by lyubodelev; 30 May 2018, 21:54.
There are currently 1677 users online. 0 members and 1677 guests.
