[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by supermal View Post
Originally posted by Novato View Post
Do not try this firmware on your MECOOL M8S PRO L. Firstly firmware compatible with the M8S PRO is not compatible with the M8S Pro L. Second, no other firmware will support DRM L1 on your device. Third, there are already 2 topics of ATV firmwares for your device here in the forum. But you can search for the topic of your device also in the forum 4PDA.
Originally posted by lyubodelev View Post
Originally posted by Novato"The firmware is made from a blank sheet based on the Ugoos AM3 2.0.6 stock system. All features and functions of the Ugoos AM3 system are preserved. The blend of features of Ugoos AM3 2.0.6 and Android TV is a devil's party. Xiaomi Mi Box just smokes nervously behind the scenes." lol
Thank you for the link
Originally posted by mirbg View Post
Is this firmware better than Magendanz's modded versions of Videostrong/Shiningwood?
working on abusing my Mini M8S Pro-C... tried flashing it, did not load properly, but my boot loader is locked and may have to do repetitive back to back flashes, because of the inherent issues with firmwares not functioning properly with a good flash. Will try reloading that firmware again, once I feel up to it. I expect a lot of error flashes, and a bit of fighting with flash tool versions.
oddly enough I installed an ATV firmware that seemed easy to install, but am having flash issues again. Eventually I hope to have the AM3 flash working on my box some time, to see how good it really is.
Originally posted by X92-2GB
It would be impossible to beat it... solid and does what you want in a TV box with ATV.
Is it also suitable for M8S Pro 3/16?
From what I understand, 3GB loosing 1GB won't be an issue, as 3GB is way too much reserved to system. Heck, my old kitkat tablet is 2/16 and still kicks butt, and I multitask more than I would on TV. Plus my apps are more memory intensive.
It works only with Mecool M8S Pro 2/16!
1. Download and brush with the USB Burning tool the Official IMG.file for Ugoos-AM3 (V 2.06);
https://mega.nz/#!eolxlKAD!1G8o_vAy2...A1XpfwPnPoVWpg
2. Replace the file Root\system\etc\remote.conf (I prefer Root explorer);
3. Run TWRP and install the patch for the Ethernet adapter (install from zip).
https://sites.google.com/site/lyubod...edirects=0&d=1
Flash at your own risk! Back up your data first!
Originally posted by lyubodelev View Posthttps://sites.google.com/site/lyubod...edirects=0&d=1
INSTALL zip with TWRP.
http://162.220.166.70/tv-box/pp_1821...ml?wid=1433363 looks like mecool m8s pro is now being shipped with widevine l1 support.
Originally posted by supermal View Posthttp://162.220.166.70/tv-box/pp_1821...ml?wid=1433363 looks like mecool m8s pro is now being shipped with widevine l1 support.
FYI, I had a recent firmware update for my Mini M8S Pro-C, it had upgraded all the drivers, and enabled one of my USB ports to be USB3. Maybe that will be the case for the new L1 edition of the M8S Pro.
IMO, if you have an over 65" 4K TV widevine will help with best picture. Though if I spent money on a 4K TV, I would have bought a Shield TV box to go with it.
Originally posted by X92-2GB View Post
Just be careful about how you flash... you can kill widevine if not careful. It has is own partition and coded with the devices serial number. So one widevine will not work with another box.
I have a shield TV but not a 4k TV.not yet anyway.i hope I can install ugoos atv firmware on m8s pro when I get it and still retain widevine L1 for hd netflix.
There are currently 3051 users online. 0 members and 3051 guests.
