[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
2.1.4. Changelog:
1. Fixed rebooting device after sleep
2. Fixed going to sleep if disabled screensaver
3. Fixed gamepad settings work
4. Updated Ugoos Log Viewer:
- fixed some bugs
- code omptimization
- now the kernel logs are written as they are received
5. Other improvements
You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by lyubodelev; 25 July 2018, 00:03.
Originally posted by supermal View Post
tried to update 2.1.3 to 2.1.4 still get error in twrp.when i ticked verification twrp accepted but failed due to error in dtb.dont know what that means.
After a success, if lan is not working, install the new patch for it.
And don't forget to enable root, whatever you try to do!
Originally posted by lyubodelev View PostSo, 2.1.3 is working for you. Try to install 2.1.3 again, but do not apply the patch for lan on it. Leave it without the lan patch (it is a part of the dtb) and thus try to update to 2.1.4.
And don't forget to enable root, whatever you try to do!Last edited by supermal; 29 July 2018, 22:33.
still get dtb error in twrp.maybe i need to put new lan patch on first.can you upload link please for new patch.Attached Files
Originally posted by Novato View Postnow that i saw it, it was lyubodelev that posted there in forum 4pda.
http://4pda.ru/forum/index.php?showt...ost&p=71080320
If you like it, patch the lan driver and add remote.conf support.Last edited by lyubodelev; 30 July 2018, 04:36.
Hey there,
M8S Pro+ here!
thath you so much for this amazing rom.
love atv, tired first time thanks to you.
so, everything worked fine for 2 days. except a couple of freeze with black screen but always when tinkering with setting.
I haven't opened it, so no idea if I have the bad emmc but I don't care.
Today Netflix stopped working, nw-6-404 & ui-113. can't even login.
factory reset, reinstall, wipe cache, wipe data, no luck.
did everything google has suggested. called Netflix, they suggested to downgrade the app... no luck
rom installed using ota stock update.
Netflix on PS4 works, t95z stock works great, mobile phone works great, browser works great.
is anybody else experiencing this issue? suggestions?
There are currently 1671 users online. 1 members and 1670 guests.
