[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
    Click image for larger version  Name:	Screenshot_20180713-204411.png Views:	1 Size:	177.4 KB ID:	735492Click image for larger version  Name:	Screenshot_20180713-204429.png Views:	1 Size:	794.0 KB ID:	735493Click image for larger version  Name:	Screenshot_20180713-204523.png Views:	1 Size:	658.1 KB ID:	735494Click image for larger version  Name:	Screenshot_20180713-204619.png Views:	1 Size:	339.0 KB ID:	735495Click image for larger version  Name:	Screenshot_20180713-204750.png Views:	1 Size:	415.6 KB ID:	735496Click image for larger version  Name:	Screenshot_20180713-210142.png Views:	1 Size:	266.1 KB ID:	735497Click image for larger version  Name:	Screenshot_20180713-215049.png Views:	1 Size:	314.1 KB ID:	735498
    Originally posted by supermal View Post
    update.now got my m8s pro 2gb/16gb with drm l1.installed am3 atv modded firmware but check with drm info says l3 support.
    I brushed successfully Ugoos-AM3 2.1.3.
    But don't try to do that in the "standard" way! - it will be not successful!
      Thanks for letting me know of latest update.woud you care to share how to do it?l have hit a wall at the moment.i need to modify the firmware somehow so that it works at widevine L1 but that's beyond my capabilities.i will have to seek some help from my contacts to see if it is possible.otherwise this firmware is best out there.version 2.1.1 is the only one available to me at the moment.update.now got am3 2.1.3 on my mini m8s pro.
        Be carefull!
          thank you for download links.i take it this is not the atv version but shiningsworth firmware?i will try it out.what method do i use to load?
            Originally posted by allandacruz89 View Post
            I can't reproduce this error... I've been using netflix tv normally.. The only one error that I've got here was the youtube, but as confirmed few posts ago in 905x ROM, the problem was in the Youtube APP...
            Did you do a clean install, with all wipes?
            what a version of netflix you use? Well, I did the OTA uptdade and selected the two options to clean of the APP Uptade
              Run DRMinfo app and tell us what Widevine level your box is supporting.
              I will do that in a few minutes and post here
                Don't try to install on Mecool M8S Pro - the result will be "black screen".
                I have made an install procedure on 4pda.ru, using recovery from backup with TWRP.
                http://4pda.ru/forum/index.php?s=&sh...ost&p=75053631
                Make Recovery from Backup with TWRP (System + Boot) over the installed 2.0.6 version.
                  https://drive.google.com/uc?id=1TTKF...xport=download
                  could not get twrp installed to make recovery from backup.
                    I've been running this on the regular mecool Pro for a long time work perfect for me other than when it goes into sleep mode you have to restart because Wi-Fi won't connect but other than that I have no problems
                      Hello! I update another time my Mecool m8s Pro+ to this rom: http://freaktab.com/forum/tv-player-...android-tv-7-1 and the netflix problems persist, I've tried to use the app DRM info by Playstore but it don't open... Another method to see what Widevine level?
                        Don't install it. Place it in the form of recovery.img on the root of a flash drive or a SD card and reboot in recovery (for Ugoos you must unplug and plug in again, holding pressed the reset button).
                          I can't understand what happened. Netflix with problem, DRM info too.. Very strange... I really doesn't know how help you... Last try would be after flash, go to recovery and wipe your ROM, (wipe for a new install in TWRP), reboot and pray..
                            This thread is the the Mecool M8S PRO, NOT the PRO PLUS. You are referring to the PLUS box, which one do you have, the PRO or the PRO PLUS??? They are two different animals.
                              Hi! I have Mecool M8s Pro+, i'm sorry i din't know this topic is just for mecool m8s Pro not for Pro Plus.
                                I don't know what happens with the netflix, I was using the stock rom of Mecool m8s pro plus and one day the netflix app stop working and that is the reason that I upgraded for nexus rom
