[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
I believe Netflix has revoked the L1 or HDCP license that this device has. But the L3 must be working, because in the my device it's ok. I use Netflix for mobile since always and it works normally. Maybe it's time to get used to this reality. As they say here in Brazil: Accept that it hurts less. lol Or you can buy a MiBox 3.
Originally posted by Novato View PostI believe Netflix has revoked the L1 or HDCP license that this device has. But the L3 must be working, because in the my device it's ok. I use Netflix for mobile since always and it works normally. Maybe it's time to get used to this reality. As they say here in Brazil: Accept that it hurts less. lol Or you can buy a MiBox 3.
SOLUTION: App NETFLIX HD Working Again!
For Only Mecool M8S Pro (L/W) with DRM L1. Device's with DRM L3 no has support.
1° Download and Install this > App <
2° Reinstall Netflix ATV on Play Store
3° Go back to Burnkey tools App
4° Now click in "Click to Burn Key"
5° Reboot Device and Open Netflix.
*Obrigado ao Canal Loukos por Android por disponibilizar esse "patch", embora não funcione no meu.
Source: ewerdroid/loukosporandoid
Hi lyubodelev , can you give me a Help? My device was often having issues with YouTube, so I uninstalled the update. I went to watch yesterday and locked the box so I hung up. I went to watch YouTube again today and locked the box so I hung up. To my surprise it did not start any more, at some point showed the Nexus Logo and in other bao showed nothing. I tried to flash some firmware here with SD Card (I always did so) and it's no problem, the flash does not start. Any idea?
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by Novato View PostThis is the sequence: I turn on the device, hit the reset button, pick up a green screen, start flash mode, reboot, show the kernel logo, reboot into Flash mode and stop without starting the upgrade. I have tried other firmwares and the result is the same.
Your problem seems to me to be in the charger...
There are currently 2343 users online. 1 members and 2342 guests.
