[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by lyubodelev View Post
Originally posted by supermal View Post
not having much success for some reason.i have two mecool m8s pro boxes.one with reset button one without.so i will try to get ugoos am3 2.1.3 on the box that has reset button first.can you help me to find where i am going wrong.can you give me a link to the 2.0.6 firmware that must be installed on the box first.does this firmware have twrp recovery already installed?if yes can you send link again for the twrp recovery from backup that will upgrade to am3 2.1.3.this is to make sure im using right firmware to get latest am3 rom on my mecool m8s pro.if i get that done ok i will try to get it installed on the one without the reset button that has widevine l1 support.each box presents different challenges.thank you in advance as you have been very supportive for me previously.
I will send you a suitable TWRP. You can easy make your own "reset button" with wires, or by short pinning .
By the way, I brush my Mecool without pressing the reset button. Pressing START on USB BT brings an error, than I unplug and than again plug the USB cable into the box and it is brushed successfully. Here is the TWRP that I use:
https://www.dropbox.com/s/aybm0ssx01...2.1-0.img?dl=0Last edited by lyubodelev; 17 July 2018, 20:38.
Originally posted by lyubodelev View PostBy the way, I brush my Mecool without pressing the reset button. Pressing START on USB BT brings an error, than I unplug and than again plug the USB cable into the box and it is brushed successfully. Here is the TWRP that I use:
success!!!thank you so much for your support.just need lan patch and all is good.got it on pen drive somewhere.lol.i take it i do not use ota update with this rom?
Chinese made "poison" defense - the result is "black screen". So disable automatic search for update...
just to let you know.i did a twrp backup of am3 2.1.3 on my mecool m8s pro with reset pin and restored onto my mecool m8s pro without reset pin.worked a treat!
New version 2.1.4 appeared...Last edited by lyubodelev; 23 July 2018, 20:11.
It turned out, that there are small differences in the DTB between 2.0.6 and 2.1.3 with no effect on lan speed, but to be correct the lan patch for 2.1.3 is different from that for 2.0.6. That's why I replaced it on 4PDA.ru. If you can't download it, I will send it to you.
New version 2.1.4 appeared...Last edited by supermal; 24 July 2018, 11:21.
There are currently 1759 users online. 0 members and 1759 guests.
