[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
    Hello
    on M8S pro L I followed the step to move to android tv, with M8S_PRO_L-ota-20180205.111652.V0928-fixed.zip
    everything happened as said on the tutorial, but now I have a blue screen and on it: hold "-" and "ok" while holding the remote near the box,
    what should I do, what is this "-" on the remote control?
    thank you in advance, this screen is beautiful, but I would like to leave,
    have a good day
    a +
    (google traduction)
ID:	714333Click image for larger version
      I would try volume minus.
        i try, nothing
          the remote control is operational, if I press return (below the "-" volume), I leave this screen and find myself on a blue screen, then nothing, but the volume button works, the button also off, I can turn it off, but reboot back to this config screen from the remote
            Same here. The power button was present on the Feb. release (my first TV box flashing experience, actually).
            Other differences:
            1. There is no status bar with notifications any longer.
            2. The Russian system language is really bad (wrong spelling and grammar). Not sure about other languages except the "default" English.
            Just returning the February version, there are two versions of ATV firmware currently for our M8S Pro. The one based on VideoStrong, which is the firmware stock of this device and the one based on Shiningworth which is the firmware stock of other models but works on our device. Apart from the fact that it does not have DRM L1 (Netflix HD) permissions it does not lose anything for the badeadi firmware in VideoStrong, on the contrary it is much superior and has fewer bugs the version based Shiningworth. In case my M8S Pro is older and so does not have DRM L1 then using the ATV firmware based on Shiningworth is vital.
              Hello
              have a good day
              a +
              (google traduction)
              Click image for larger version  Name:	image_31551.jpg Views:	1 Size:	104.4 KB ID:	714333Click image for larger version  Name:	image_31555.jpg Views:	1 Size:	94.3 KB ID:	714339
              Well, this tutorial here and the firmwares here are only for the M8S Pro (Without L, Plus or W), so first check if your M8S Pro has L if you go in post M8S Pro L, if not If you have L you may have installed a wrred firmware, which caused this error.Well, this tutorial here and the firmwares here are only for the M8S Pro (Without L, Plus or W), so first make sure your M8S Pro has L printed. If you have L, I recommend that you seek help in the ATV topic for the M8S Pro L. But if you do not have L printed, you probably have installed an incorrect firmware. And that may be the reason for this error in detecting control. It's also important to see if it works like a mouse or gamepad.
              Edited
                Pardon me, but could you rephrase this?
                It's not really clear from your wording which is superior to which
                  The Shiningworth's version is better than Videostrong's one.
                    You mean you understood what the previous poster said or you mean you think that Shiningworth is worth it?
                    I'm asking just because you also asked about which was better a few posts above.
                      Both
                        Im sorry ... I meant that if your TV Box does not have DRM Level 1, it is better to use February firmware.
                          Exactly, thank you for deciphering my hard-to-understand words.
                            Originally posted by Magendanz View Post
                            Changelog (20180310):
                            Thx for update!!!
                            you Nexus rom is my favorite.
                            Shiningworth's version have a nice features but for my is "Nexus" better. thank for your work!
                              this wizard is for parring BT remote but you have (normal) IR remote
                              https://gloimg.chinabrands.com/cb/pd...5818_66333.jpg
                                After the update:
